EMERGENCY petrol indicator ............. |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:43 | # 1 |
I would like to consult you my distress. I had a problem with the gasoline indicator yesterday. / div> I bought 50 TL gasoline again and again why it is not extinguished, I am waiting for your comments please I'm sick of it anymorekkkkkkkkk .................
| 08.05.2020 16:43 | # 2 |
xpyhre |
Descriptions on this topic are available in the forum. If you do a little research, you will find the answer. There were friends who encountered the same mistakes. Have a nice day.
| 08.05.2020 16:43 | # 3 |
I know, but I searched, I searched, I couldn't find some kind of site. & nbsp; thanks for support.
| 08.05.2020 16:43 | # 4 |
xpyhre |
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=22552&title=benzin-gsterge
| 08.05.2020 16:43 | # 5 |
i read it before but the problem is not in the sockets
| 08.05.2020 16:43 | # 6 |
xpyhre |
The gasoline float might have been installed at that time. a bit deeper & nbsp; After wandering around, the float can escape from its place. If there is a quarter tank of gasoline, the light will still be on, not until you run out of gas. Then consult with the master.
| 08.05.2020 16:43 | # 7 |
Celalll |
After I waited in the parking lot for a while in my car, the needle did not improve even though I received 20 TL gasoline twice. After a while he recovered himself. I don't think you need to panic.
| 08.05.2020 16:43 | # 8 |
MuratUlg |
As far as I know, it is not necessary for the diesel or gasoline to exceed 6 liters or the vehicle does not detect it, so it does not increase in the hand. Perhaps there may be a problem with the dial, if it was previously played, in order not to take more than 6 liters.
| 08.05.2020 16:43 | # 9 |
[QUOTE = MuratUlg] As far as I know, it is not necessary to use the diesel or gasoline to exceed 6 liters. Maybe there is a problem with the dial if it has been played before or not to be taken more than 6 liters. [/ QUOTE] 7 liters. |
| 08.05.2020 16:43 | # 10 |
thanks a lot. |
| 08.05.2020 16:43 | # 11 |
Increases are: D |
| 08.05.2020 16:43 | # 12 |
Park the vehicle on a steep ramp with the nose down, remove the key from the ignition, wait 1-2 minutes, shake the vehicle a little strongly. Of course, it must be at least enough diesel in the warehouse to exceed at least a quarter :)
