Emergency - My Vehicle Doesn't Work
08.05.2020 17:10 # 1
murat20021978
Hello friends;
2006 I have a Model 206 x design. I just started the starter. the vehicle worked at high speed then stopped. Then I started again, the starter is running, but the engine does not start. I ask for help from friends or masters who have encountered such an event before.
08.05.2020 17:10 # 2
xMEGANx
Get well soon, I think it's a Fuel problem.
08.05.2020 17:10 # 3
Zagorka
Replace the diesel filter first, maybe the poor quality diesel filter you bought dirty and blocked it, if the problem persists Get a carbon clean and get well soon.
08.05.2020 17:10 # 4
murat20021978
Vehicle gasoline friends. Unfortunately, I still haven't got it to work. However, I talked to several masters. It was said to be from a petrol pump or injectors. I always bought gas from the gas station I went to. I have not had any problems with gasoline so far. There is a gas pump under the back seat. "Hit it several times with the back of the screwdriver," said the master. Unfortunately, we did not get any results. I think they will handle it on weekdays. I write the result here. At least if they happen to other friends (hopefully not) they have an idea.
08.05.2020 17:10 # 5
Serkan
Get well soon, I hope it is something simple and incompetent
08.05.2020 17:10 # 6
murat20021978
The problem is solved, guys. Gas pump engine malfunction. Normally, the entire gas pump was changing (400 TL). However, the repairman friend solved the incident for 75 TL. they changed the engine inside. When we said a little bit of labor, we got the problem. The car is running smoothly now.
08.05.2020 17:10 # 7
cihanpasam
get well, my chief.
08.05.2020 17:10 # 8
murat20021978
Thank you for the interest of all my friends. I hope none of us stay on the road :)
