EMERGENCY INFORMATION
08.05.2020 15:49 # 1
Gokhan_S
FRIENDS 2001 I RECEIVED THE MODEL PEUGEOT 206, I HAVE A SLEEVE LENGTH SLEEVE ON THE RIGHT SIDE OF THE STEERING, I HAVE NOT SURVEYED WHAT IT DOES.
08.05.2020 15:49 # 2
Gokhan_S
AND ALSO HOW CAN I UNDERSTAND WHAT I HAVE ABS IN THE VEHICLE
08.05.2020 15:49 # 3
The tape is the control arm, under the wiper arm ..
08.05.2020 15:49 # 4
Gokhan_S
When I say tape control arm? I do not understand
08.05.2020 15:49 # 5
First of all, your car is good, it is the tape control which is the finger-length arm tape and the well-kept tape control.
08.05.2020 15:49 # 6
Gokhan_S
I'm a novice friends, my first car was a peugeot, I turn the ignition one click, the battery is red, I turn it 2 clicks, to the left of the panel, a yellow lamp is on, I don't start the starter before I turn off that light
08.05.2020 15:49 # 7
estafurullah why do we want to help you as much as we can,
08.05.2020 15:49 # 8
Gokhan_S
I bought gasoline at 81,000 km
08.05.2020 15:49 # 9
When the sole contact is switched on first, the safety belt is on the left side, the airbag is on the right side, and the yellow light is on the right side, and the right side is on the right side, the battery is on the right side and the engine is on the right side.
our ahmetsk 2011-07-13 23:44:52
08.05.2020 15:49 # 10
Gokhan_S
I don't have a snow tire, do you have to wear a snow tire in winter?
08.05.2020 15:49 # 11
MemoTech
May your car be beneficial but do not go so fast.
For ABS, if you brake suddenly in a clean place (without vehicle traffic), if your vehicle is skidding on the brake, ABS does not slip and if the brake pedal hits under your foot, there is ABS.
08.05.2020 15:49 # 12
with this method knows if there is abs
08.05.2020 15:49 # 13
Gokhan_S
What is the life of the current tires? I mean, it's been 4 years, but the teeth are good, when should I change?
08.05.2020 15:49 # 14
I do not look outside, but if you are able to eat the cheeks, if you have eaten, I will advise you to remind you because there are no question marks.
08.05.2020 15:49 # 15
Gokhan_S
which brand ?
08.05.2020 15:49 # 16
[QUOTE = gökhan_s]
If the second contact is on when you open the second contact next to the airbag lamp in the upper left corner and it says abs, it means there is abs in the vehicle.
08.05.2020 15:49 # 17
Gokhan_S
Thanks guys, it was useful
08.05.2020 15:49 # 18
we reca
08.05.2020 15:49 # 19
gami06
I WANT TO CONSULT SOMETHING TODAY I RECEIVED 2004 MODEL AUTOMATIC 206. THERE ARE TWO BUTTONS BITS ON THE SIDE OF THE GEAR-S- WHAT IT MEANS WHAT IT MEANS HOW IT SHOULD BE USED :) I CHOOSE THE FORUM SITE, EVERYONE SHARED THE INFORMATION :)
08.05.2020 15:49 # 20
[QUOTE = gami06] I WANT TO CONSULT SOMETHING TODAY 2004 MODEL AUTOMATICALLY GOT 206. THERE ARE TWO BUTTONS BITS next to the gear -S- WHAT IT MEANS ME WHAT IT MEANS ME HOW TO USE :) I CHOOSE IT FOR THE SITE SITE: EVERYONE SHARE ITS INFORMATION:) [/ QUOTE]
my friend has forum rules first introduce yourself then follow the lower case rules
respects
Page : / 3
