Emergency indicator warning lights error
08.05.2020 21:23 # 1
Devrim
Hello friends, I would like to hear from you about a problem, the car is not running, the indicator lights are on when the car is parked and locked, the petrol indicator light and the stop warning light are constantly blinking for a while, then it stops and continues again. and therefore I take off the pole constantly, also after the car starts, this error does not happen until the time I stop and lock it.
08.05.2020 21:23 # 2
First of all, welcome to us. the problem is a charger or a battery related situation. there is a possibility of oxidation in the fuse box or a shortage of chassis (electricity). If you are in Ankara, they will help you if you can go there.
08.05.2020 21:23 # 3
Devrim
Thank you very much bs brain said they are likely to be hungry
08.05.2020 21:23 # 4
[QUOTE = Revolution] Thank you very much bs brain said they are likely to be hungry [/ QUOTE]
The last option is to connect to the vehicle with a PC and check if there is any malfunction.
08.05.2020 21:23 # 5
Devrim
Thank you again I hope I will go to the place you suggested
08.05.2020 21:23 # 6
ismailkaya
you can also contact
08.05.2020 21:23 # 7
Devrim
I ask him when I go to the master thank you
