emergency help when the contact is open
08.05.2020 20:19 # 1
mert2147
When the emergency aid opens the contact, the temperature indicator goes up to the ceiling and goes down very quickly 3 times later at the very bottom.
08.05.2020 20:19 # 2
aykutbayram1996
The temperature officer may be broken, show a master.
08.05.2020 20:19 # 3
mert2147
1 week after he did the same thing he did before, it was the same again, then there was a problem in the brain, the master had done it, now it was the same again, and when the car started last night, the fan was not working, the temperature was stopping because it had risen, now it does not work at all.
08.05.2020 20:19 # 4
ruhela
Replace the Thermostat completely instead of the sensor. First of all, the same thing happened to my friend, he made a ceiling at the first starter and fell back a few times. Things like springs, etc. in both the sensor and thermostad may be damaged.
08.05.2020 20:19 # 5
mert2147
So when you pressed Marsa, your friend was working
08.05.2020 20:19 # 6
mert2147
By the way, which sensor are we going to replace?
