Emergency Help Gentlemen, Give an Idea
08.05.2020 15:19 # 1
g-demir
Guys now I got the amp, tied it up. Since my tape was original, I plugged it through the loud audio inputs. There is also a ground connection of these loud sound inputs and I connected it to the main chassis part.
sound quality is good, power is smooth. but the problem is this: there is an amazing buzzing noise whisper whatever you say sound. sometimes there is a sound as if the cat is moaning. it makes noise from somewhere but i couldn't find where. On the other hand, I plugged the remote connector directly from the antenna output to the antenna cable, but the amp remains on until the car goes into economy mode even when the tape is off. why do you think it might be?
08.05.2020 15:19 # 2
Muhammet CAKIR
There are cables going from the tape to the amplifier, RCA cable is known. Any one of those cables will cut the sound on the end of the end of the cable and connect it to the chassis.
08.05.2020 15:19 # 3
mdincer34
If the amplifier is turned on by triggering when the tape is turned on, does it not need to turn it off when it turns off?
08.05.2020 15:19 # 4
g-demir
[QUOTE = Muhammet ÇAKIR]
Mine was original tape, I couldn't connect it from RCA. There is an input for the cables of the tape going directly to the columns, I plugged it there. How to do?
08.05.2020 15:19 # 5
Muhammet CAKIR
If the amplifier is hungry, I could not understand the connection of the remote cable to the antenna: I do not know if you have the original tape, but a blue cable should be connected to it.
08.05.2020 15:19 # 6
g-demir
I made a 3-key to the bottom of my knee for different purposes. I connected it to him first, then I said "everybody is connecting to the antenna, so I do it, it says both in the booklet" and I connected it to the antenna. but when the tape is turned on, it opens, and when it is closed, it does not close And when he goes home just before, doesn't he turn red light and go into protection mode!
i am willing to switch event just enough to handle that noise sound event
08.05.2020 15:19 # 7
Muhammet CAKIR
[QUOTE = g-demir] I made a 3-key to the bottom of my knee for different purposes. I connected it to him first, then I said "everybody is connecting to the antenna, so I do it, it says both in the booklet" and I connected it to the antenna. but when the tape is turned on, it opens, and when it is closed, it does not close And when he goes home just before, doesn't he turn red light and go into protection mode!
[/ QUOTE] the room may be a factor, I did not think of it :)) take it out by dropping +12 v give it run, hear the sound if my voice is not interrupted, do what i say bro :)
08.05.2020 15:19 # 8
g-demir
[QUOTE = Muhammet ÇAKIR] [QUOTE = g-iron] I made a triple key to the bottom of my knee for different purposes. I connected it to him first, then I said "everybody is connecting to the antenna, so I do it, it says both in the booklet" and I connected it to the antenna. but when the tape is turned on, it opens, and when it is closed, it does not close And when he goes home just before, doesn't he turn red light and go into protection mode!
[/ QUOTE] the room may be a factor, I did not think of it :)) take it out by knocking +12 v give it run and hear the sound, if the sound is not interrupted, do what i say bro:) [/ QUOTE]
I'll take it out of the antenna and give it 12 directly. but would it be useful to land the rca inlet while there is no RCA connection? Confused
08.05.2020 15:19 # 9
Muhammet CAKIR
[QUOTE = g-iron] [QUOTE = Muhammet ÇAKIR] [QUOTE = g-iron] I made a 3-key to the bottom of my knee for different purposes. I connected it to him first, then I said "everybody is connecting to the antenna, so I do it, it says both in the booklet" and I connected it to the antenna. but when the tape is turned on, it opens, and when it is closed, it does not close And when he goes home just before, doesn't he turn red light and go into protection mode!
[/ QUOTE] what did you carry with the amplifier that sounded: RCA cable without DCA cable You have to connect a cable to the outer circle (which is MEtal) and give it to the chassis, Muhammet ÇAKIR 2011-04-24 00:28:26
08.05.2020 15:19 # 10
g-demir
I carried it without this. There is no RCA output on the original tape. There is a cable from the tape directly to the column, I put it in the amp. the amp has a private entrance for it Göz Kırpma
08.05.2020 15:19 # 11
Muhammet CAKIR
okay then - you will make a chassis connection to the cable :)
08.05.2020 15:19 # 12
MemoTech
When I said I connected it to the antenna? Did you connect it to the normal antenna output? When they say antenna, they mean the electric motor antenna in the booklet. So if there is tape feature. When the tape is opened, there should be a dedicated outlet for the antenna that opens up by itself. You will ensure that the amp is turned on with the electricity coming there.
08.05.2020 15:19 # 13
F-Eren
makes buzz from chassis
As my friend says, tie the chassis from the cable well
08.05.2020 15:19 # 14
tigerland
For someone who understands the sound system without any disability, make the amp setting and show the links.
08.05.2020 15:19 # 15
by-cx
brother go go listen like a converter, or when you plug in the original tape, all of them deteriorate the sound quality. Don't worry, don't be easy.
08.05.2020 15:19 # 16
g-demir
the problem is sound development. The sound is clear and perfect when I plug in a device (I plug my phone) with normal RCA connection. But when it comes to the colon line, it spoils the job. I will buy a tape now :)
yes I connected it to the normal antenna output, it was wrong, I connected it to a separate 12v switch, it was smooth.
Thanks for the ideas, guys, don't be missing Thumbs Up
08.05.2020 15:19 # 17
dinoco
[QUOTE = g-iron] problem is sound coming. The sound is clear and perfect when I plug in a device (I plug my phone) with normal RCA connection. But when it comes to the colon line, it spoils the job. I will buy a tape now :)
:) you are super you cant find anything :)
My friend, plug in the converter that performs the original tape amplifier output. I'm serious that the system won't last long. I wish you good forums
08.05.2020 15:19 # 18
metin
some of the converters were soldered with my solder or something, and my plumber recommended a converter that adjusts itself, which is 10 TL more expensive, I hope I will do it from him.
08.05.2020 15:19 # 19
dinoco
When I mean EVT, only one socket converter performs an automatic conversion.
