emergency help friends !!!
08.05.2020 17:12 # 1
tayfundoner
When my friends were on the road last night, my speed was around 90, the car locked the front tires, opened it again, immediately burned the quads right, I approached the engine, it was working strangely, I immediately stopped the car, I opened the hood, the engine was gone around, I leaned, I looked at the service, why did I go to the service? I would be very happy if you help.
08.05.2020 17:12 # 2
murat20021978
I think you burned the engine seal. Get well soon.
08.05.2020 17:12 # 3
Bugra
I think my friend is a bed-wrapped vehicle. If you have pierced the crankcase, oil has flowed and the pistons of the lean vehicle are locked and the tires are locked as a result. As I guess, the vehicle has a lot of expenses, get past.
08.05.2020 17:12 # 4
tellotello
Have you rubbed the gold somewhere? For the past, it seemed like a troubled situation, but no construction.
08.05.2020 17:12 # 5
cgty86
probably the bed wrapped vehicle was left without oil and the piston or something broken. complete engine needs to be done, get past & nbsp;
08.05.2020 17:12 # 6
xMEGANx
Why are friends wrapping the bed? just because it's left without oil?
08.05.2020 17:12 # 7
Barut
[QUOTE = xMEGANx] why are friends wrapping the bed? I just know that because it is oil-free?
08.05.2020 17:12 # 8
tayfundoner
how much will the average cost friends?
08.05.2020 17:12 # 9
tayfundoner
[QUOTE = tellotello] Have you rubbed the gold somewhere? For the past, it seemed like a troubled situation, but it won't be built. [/ QUOTE]
There is no visible hole in the cartel from below, man.
08.05.2020 17:12 # 10
tellotello
So did you find where the oil comes from? As the friends say, bed wrap is a big expense, teacher, but it is like cancer, early diagnosis is of great importance. If he is sure that the oil is draining and thinks it is for this reason, the master can turn on the engine and tell you the magnitude of the problem. The earlier you noticed it, the more advantageous you are. I hope the results are not as we hoped. In a possible bad scenario, the master is very important in these works, try to show it to a good master. Again get well soon.
08.05.2020 17:12 # 11
tayfundoner
thank you guys but the cost is too big, the pistons are broken, the engine block is cracked, etc .. they said they said sewing the engine blog or you will find it out there is a cost like 4000 tl?
08.05.2020 17:12 # 12
serdar5252
Get well soon :(
08.05.2020 17:12 # 13
ufuk91
I am very sorry, what I mean is 4000 lira, I would like to get past it ... I will either get your car done or write it out by writing the price according to it & nbsp; "Ermm"
08.05.2020 17:12 # 14
Zagorka
The problem was similar to me, the strange sound was starting to come from the engine. I don't remember what happened.
08.05.2020 17:12 # 15
nucro
Man, get well soon. arm whatever you live in industry & nbsp; It is called decal. The bearing-wrapping motor breaks the piston rod and breaks the blog. The lightest cost is 3000 TL.
There may be many reasons for this. the engine is oil-free, it is caused by overheating water from the cracked motor oil, the lack of lubrication due to dirt, the engine is deprived of its life as a result of neglect, or constant excessive force (which I have not seen as an example to this day).
To learn the most logical solution code of the engine, find a clean engine with scrap certificate and invoice and install it in your vehicle. then, of course, you can get it approved by tse and have a check on tweed and run the new engine from safety. If you are in Ankara, I know 1-2 people who will help with the safety of tuv. They should have been known to me.
A very challenging process is waiting for you.
08.05.2020 17:12 # 16
gngburak
God bless the bet, get a great history gngburak 2012-12-19 10:43:34
08.05.2020 17:12 # 17
tayfundoner
friends, thank you very much for your interest, we will make the vehicle 4000 TL.
08.05.2020 17:12 # 18
Semih CAVDAR
Get well soon :(
08.05.2020 17:12 # 19
tellotello
Well, I guess, my worst scenario has happened and the engine has been wrapped. If you trust the master, if you know his past experience, I say keep you cool. If the products used are original, construction will be something you want and you will use it with peace of mind. Again get well soon.
08.05.2020 17:12 # 20
tayfundoner
We trust the master in our own way, we went with the guidance of the peugeot service, but we will see the result.
Page : / 2
