Emergency Help
08.05.2020 17:16 # 1
tolgatufekci
First of all, hello, my car 2004 1.6 Gasoline 307 XT model did not work recently when I turned the ignition on my car, it was working normally, but it was not working. I stopped again, I had the same problem with violence, I called the engine master, said the battery, went, got the battery, put it on, got up in the morning, the same problem continues, I hit it and started it on the screen, I encountered the error of "antipollution fault", I came home, the malfunction lamp went out in front of the door, my vehicle stopped working at idle for about half an hour. There was no problem.I got stuck in my head, stopped and stopped the same corner so that I could take a tour, gave the same error, no matter how hard I tried, did not try to hit it, we came to the front of the house by pushing. I closed the contact myself, I could not get it working again, I need urgent help. What can be the problem?
08.05.2020 17:16 # 2
gravedigger58
Well, if there is a tube in my teacher, I will comment accordingly.
08.05.2020 17:16 # 3
Serkan
[QUOTE = gravedigger58] valla hocam, if there is a tube, I will comment accordingly [/ QUOTE]
I changed the tube filter.
08.05.2020 17:16 # 4
tolgatufekci
Yes, I have atiker brand tube in my car. I tried again a few hours ago, I did not handle it for 2 hours. The car was rested, I started the starter, it worked a long way. I used it at high speed 3 times.
08.05.2020 17:16 # 5
emin15
If
is doing the same problem in the tube, in the ignition coil or engine & nbsp; There may be a problem with the speed sensor
& nbsp;
08.05.2020 17:16 # 6
Burak
I was able to translate it just because my help touched it was the pollution error :) Check the filters over and over again according to the given error, I think you can take the vehicle with the tow truck to the master
08.05.2020 17:16 # 7
muratoner
& Nbsp; & nbsp; Nowadays, the weather is cold & nbsp; gas from a quality place, make sure you won't encounter this problem again.
08.05.2020 17:16 # 8
tolgatufekci
[QUOTE = mekuaes] I was able to translate from translated just because my help touched it was pollution error :) Check the filters over and over again. div> thank you very much for your attention, the filters had just changed, air filter or something, what will be out tomorrow: /
08.05.2020 17:16 # 9
tolgatufekci
[QUOTE = is Muraton] & nbsp; & nbsp; Nowadays the weather is cold & nbsp; gas from a quality place, be sure you will not encounter this problem again.
08.05.2020 17:16 # 10
tolgatufekci
[QUOTE = emin15] If
is doing the same problem in the tube, in the ignition coil or engine & nbsp; There may be a problem with the speed sensor. Could a sound come from the engine part?
08.05.2020 17:16 # 11
emin15
When the engine is cold, the v-belt, that is, the alternator belt, sounds, and the engine speed sensor is on the front of the vehicle between the engine and the transmission.
08.05.2020 17:16 # 12
tolgatufekci
Thank you very much for your help, my friends, we have detected the problem of my vehicle as of today, the "flywheel sensor", the speed sensor is defective, we have changed the output for now.
