Emergency Help: (307 emergency help
08.05.2020 14:13 # 1
dieselbastard
peugeut 307 1.4 Hdi I have a car, though I have looked at the front gear, it sounds like a high place: When I go 3 km, I get high on the ground like plateaus etc. I do not expect speed from the car. I just got it done, I would appreciate if there are friends who can help me :(
08.05.2020 14:13 # 2
Experienced friends will help if you introduce yourself in the related title.
08.05.2020 14:13 # 3
I wonder if I can put thick oil in the car, this situation may be caused by the oil, but the sound will sound every 307 minutes.
08.05.2020 14:13 # 4
dieselbastard
[QUOTE = laedri] If you introduce yourself in the related topic, experienced friends will help .. [/ QUOTE]
what's like bro
08.05.2020 14:13 # 5
dieselbastard
[QUOTE = polatkaptan] I wonder if I put thick oil in the car, this situation may be caused by the oil, but it sounds like every 307 minutes [/ QUOTE]
Not only that, my previously serial car is now bulky: We know there are 1.4 engines, but we do not want a speed of 200 km from it, although I did the maintenance of the vehicle going in series, the bulky oil has changed everywhere.
08.05.2020 14:13 # 6
cerci07
How many km of vehicle do you have? cerci07 2010-04-04 01:16:28
08.05.2020 14:13 # 7
dieselbastard
It is best to write my problems in the form of items and expect answers from friends.
1. Temperature: When you go to a high place, the speed of the car is rising.
Performance 2: I do not expect high performance since my vehicle is 1.4. But the first time I bought the vehicle, their series was serial, now it seems as if he did not want to go. I wonder if the injectors are blocked?
3. Front Teams: If I Have the Front Teams Look At It, Is It Sound Normal Is It Normal Or Am I Exaggerating?
4. Air Conditioning Panel Lights: The Air Conditioning Lights are not lit.If the lamp was cut off now, I don't know why my fuse was blown.
5.When I go on the normal road, I hear a thin noise coming from the wheels of the vehicle as if something is rubbing against the disks.
6. Finally Orj. I want to get information about the balata prices .. How much is the workmanship and part price ..
Car Maintenance I Made:
Timing Belt + set
Radiator Belt
Air filter
Diesel fuel filter
Oil filter
Tie Rod End
Oil Changed + Double Up Nano Added.
Labor and part money;
(490TL + 150TL)
I present my thanks for your attention ...
08.05.2020 14:13 # 8
dieselbastard
[QUOTE = cerci07] What was your km vehicle? [/ QUOTE]
96 037
08.05.2020 14:13 # 9
If the gun is smoke from the injector, the pump will be off the pump, the fault lamp will come on, there may be a problem with the turbo or the air filter has not been fully seated.
