Emergency help 207 right back door doesn't open
08.05.2020 20:08 # 1
Sercann
Hello everyone, I have a 207 model of 2010, right back door is not open from outside.
08.05.2020 20:08 # 2
If my teacher opens the door from the outside, it is likely that the door handle is faulty.
08.05.2020 20:08 # 3
Sercann
First of all, thank you for answering. I wonder if I can handle it by my own means.
08.05.2020 20:08 # 4
Well, my teacher, you can do this type of work if you are done. The 13 numbered piece seemed to be problematic, I don't think the lock is broken or it wouldn't open inside or lock out from the remote.
sonerkyl 2017-01-17 11:40:43
08.05.2020 20:08 # 5
Sercann
I wonder if there are friends who have knowledge about internal dosing
08.05.2020 20:08 # 6
teacher youtube videos available front door logic inside back door same
https://www.youtube.com/watch?v=b-wzi17cqm
08.05.2020 20:08 # 7
Sercann
Thanks are
08.05.2020 20:08 # 8
you are welcome hodja hope you solve your problem Thumbs Up
08.05.2020 20:08 # 9
onlycihan
I have had some experience since I removed the 4 doors of my 206 vehicles four times. I don't know if it is the same in 207. my backs opening the manual cam. If these arms do not hold any bolts, they will get rid of it by paying strict attention to yourself. There is a screw in the door handles, usually unscrew it and if you are sure that there are no other screws by carefully examining the inner parts of the other solid door, you can free the interior floor from its clips by slightly prying the tip with a flat tornovida. But for this procedure, tilt the back seat and remove it if possible. If you open the interior of the door only, you will see the interior insulation material first. try to disassemble the lock part carefully enough to damage the hand without much damage, but stick this material as before or you may have water intake problem like my vehicle. Good luck with
08.05.2020 20:08 # 10
Sercann
Very tessekurler teacher, I'll try it over the weekend.
26.09.2021 11:07 # 11
Sail
Sir the video is dead. Could you give another link? Also, how can I access the pejo's site in that picture?
26.09.2021 11:07 # 12
Sail
do you have a video?
26.09.2021 14:06 # 13
antipollution
You can find more videos of "207 door trim removal" when you translate this Turkish one again with youtube translate and search in English, check them out
