Emergency Help
08.05.2020 16:19 # 1
mehmetaydinpug
Hello friends, there is a problem with 106 quik ...
When I go uphill and when I go into hard bends, it cuts off the gas. flashing in some way, do the same on departures, what exactly is the problem in the oil, can you be painful, what can i do? thank you for your answers in advance.
08.05.2020 16:19 # 2
Have the past, I have the same vehicle, do you have an exhaust exhaust in your vehicle? Or has there been a problem with oil change or a similar place recently?
08.05.2020 16:19 # 3
may be in the electrical circuit breakdown, the same problem was in my old car, the oil lamp was lit up intermittently, I looked at the electrical installation, the problem passed.
when it comes to gas cut I do not know, but I can recommend you to use the injector cleaner by consulting the injector ...
it hurts when it gets 106 ... < / strong>
08.05.2020 16:19 # 4
Abart exhaust so I ask a friend had the same problem gas cut & nbsp; I asked for him like that.
08.05.2020 16:19 # 5
Haksen016
get past how many km of vehicle. Have you previously had carbon cleaner or engine cleaning, and how was the car's departure before & nbsp;
08.05.2020 16:19 # 6
mehmetaydinpug
km 93 thousand, there is no abart exhaust, there is an open air filter, I just called the repairman friend, he said it might be an oil sensor.
08.05.2020 16:19 # 7
mehmetaydinpug
I am very curious that my first job will be to share with you when this problem is solved. Let's see how much it will explode.
08.05.2020 16:19 # 8
you ask the injector cleaner, I think when the dirt comes, it kicks off gas. "
08.05.2020 16:19 # 9
basrix
does not eat gas up and down straight road there is no problem because you wrote that the car is skewed, gasoline escapes to the back of the fuel tank, the pump cannot draw the gas & nbsp;
08.05.2020 16:19 # 10
basrix
If the oil lamp problem is not from the customer but the socket that enters the customer is loose or oxidized, you do not need to change the oil pump.
08.05.2020 16:19 # 11
basrix
abarth or flat muffler contains fiber, such as beehives, they do not gas when dispersed, our friend says only the slopes on the flat road on the flat road & nbsp;
08.05.2020 16:19 # 12
mehmetaydinpug
I don't know if it could be from the silencer, but as you said, could it be from the fuel tank?
08.05.2020 16:19 # 13
mehmetaydinpug
I followed the cable coming out of the sensor and found the problem, I was holding two wires of wire or did not hold it, I taped the cable, we solved the oil lamp work, now the problem is to handle this traction job.
