Emergency Fuel Hand Problem
08.05.2020 19:41 # 1
baya1994
Since I bought the car, it has been a malfunction for several times. Okay, this time it will not be a problem. I have a problem in the fuel acceleration for 3 days. switched, i.e. to get out of contact. I went to another place, I bought another 25 TL, the water was not upset, the needle does not increase, it decreases gradually. Why this can happen. If Samandira is stuck, I say where this samandira is with my strange hand.
08.05.2020 19:41 # 2
bb-mahmut
Do not do anything, you can not do it if you want, you will break it because it is in the store :) Take it to a master.
08.05.2020 19:41 # 3
talip206
This is not a problem if the liter of gasoline or diesel of 7 liters or more is not taken at once. The needle does not play because you take it piece by piece every time.
08.05.2020 19:41 # 4
temelcelebi
I had the same problem in my car differently. The pointer constantly pointed at half a tank. I loaded a small amount of fuel like you did not recover a few times. After that, I bought 100 TL of fuel and I am not having a problem for 3 months now. When it comes to the bottom, it even lights up, so the problem disappeared. I recommend you to try this method.
08.05.2020 19:41 # 5
baya1994
I do not understand the presentation now. I know the samandiranin.It has a plastic thing and the level of fuel. Because soyle.diyey.bu.I got 15 TL for my second time in my head. I did not get up, I got 20 again. I don't understand. Whatever.
08.05.2020 19:41 # 6
baya1994
Today, I bought 25 TL, yabi bought 7.14lt and I tried samandira, I was waiting to say that it was going to be full.
08.05.2020 19:41 # 7
talip206
[QUOTE = baya1994] I bought 25 TL today, it bought 7.14lt and samandira worked, I was expecting it will be full, half-tank showed full, I did not understand where the previous 15lt went [/ QUOTE]
Your normal teacher tank, 50 liters, you have bought 22 23 liters of fuel in total. So it's okay
