Emergency fan does not turn on
08.05.2020 21:15 # 1
tolga kurt
I just bought the fan fan of friends, the original still does not turn on the fan. But when the fan is disconnected from the socket of the customer, the fan is working manually, so the fan motor is intact. If I have a suggestion or suggestion, I can get every electrician that I went to have a different random failure. I do not want to use a trial and error method.
Thank you from now Big smile 206 diesel 1.4 2007
tolga wolf 2019-06-03 02:40:51
08.05.2020 21:15 # 2
kaan206
the fan sender is separate, the temperature sender is separate
If your fan sender new roles are intact and the fan is not working, change the temperature (heat) sender.
The vehicle does not turn on the fans because it does not measure the temperature (temperature). Probably the temperature in your speedometer does not rise up to 90 c and above
kaan206 2019-06-04 15:13:23
08.05.2020 21:15 # 3
Karacocuk24
[QUOTE = tolga kurt] Friends I just bought the fan sender, the original still does not turn on the fan. But when the fan is disconnected from the socket of the customer, the fan is working manually, so the fan motor is intact. If I have a suggestion or suggestion, I can get every electrician that I went to have a different random failure. I do not want to use a trial and error method.
[/ QUOTE] As far as I know, the fan that works when you remove the socket socket does not show the sound of the role, the safety brain sends electricity, your problem is either a role or a fan resistance
08.05.2020 21:15 # 4
kaan206
There are two heat sensors in the vehicle, one is on the thermostat and the blue one is on the top cover horizontally, the blue heat sensor is checked. The problem is probably from these two heat sensors kaan206 2019-06-04 23:15:24
08.05.2020 21:15 # 5
Delfi911
He said that there is no problem in normal traffic in my vehicle, but when the traffic ramps, the temperature rises when the ramp rises and if the master swells on the ramp, the radiator will do it if he has two eyes blocked. We took the cleaner but there was no solution. The radiator has changed. Fans and overheard have changed, but the problem continues. It works when you remove the fan socket, but the fan does not work when plugged in. So I have the problem, but I couldn't solve it. Do not do what I do, keep your money in your pocket and tell me if you solve it.
08.05.2020 21:15 # 6
tolga kurt
Where is that 2nd Sender you said? Temperature is working normally
08.05.2020 21:15 # 7
tolga kurt
If you find a solution, let me know, master 05449770646
08.05.2020 21:15 # 8
tolga kurt
08.05.2020 21:15 # 9
tolga kurt
diesel but my vehicle. I've never seen anything like that on the top cover
