'' '' EMERGENCY '' 'CLUTCH REMAINED
08.05.2020 15:07 # 1
sukur
My dear masters and experienced brothers. When I left my house this morning, when I entered the gas station 300 meters away, I pressed the clutch while the gear was going to drop and press it. The ROOF sound and Clutch went down. He stuck to the mop. It has not become older again. When I lift it with my hand, it washes down emptyly. But as if it wasn't connected with anything. I left my car at Gas Station and came to work. What should I do in the evening? 98 PUG 106 XS
08.05.2020 15:07 # 2
xdesign
The sister will be handcuffed from the bottom. Clutch rope is broken. Call a mechanic. Call me and get a handcuffs. Get well soon.
08.05.2020 15:07 # 3
xdesign
Or, because the clutch spring is oxidized over time, the screw may have prevented it from coming back. Lean over and check the clutch pedal with your hand. Remove download. If you feel anything while getting up, the problem is broadcast. But if the pole was dropped blankly when it was lifted, the rope was broken.
08.05.2020 15:07 # 4
sukur
Yes, it falls emptyly, Master. how much will it explode?
08.05.2020 15:07 # 5
metin
I think the clutch wire is broken.
my father found the master who was stranded with a broadway wire and broke 50 TL including material workmanship, but I do not know 106
Get well soon.
08.05.2020 15:07 # 6
sukur
Thank you, Master, thanks.
08.05.2020 15:07 # 7
sukur
If my friends clutch rope is broken, running in 2 th gear, does it go without changing gears, the car is 2 km away from the master industry
08.05.2020 15:07 # 8
xdesign
If your pressures are not 0, you can easily shoot the car in 2nd gear by vibrating forward. You don't have any sister expenses. 10-20 pounds of manual labor.
08.05.2020 15:07 # 9
STALLONE
Get well, if you use it at low speed, it will go to physics.
08.05.2020 15:07 # 10
sukur
Eywa. Thank you, Master
08.05.2020 15:07 # 11
STALLONE
it doesn't matter what
08.05.2020 15:07 # 12
herry
I hope it will be easy, man.
08.05.2020 15:07 # 13
orhanetap
Dude, you can start the car by striking in 1st gear, if the ground is close, you can continue in 1st gear or the gear shifts without clutch 2 at high speed, probably the wire is broken.
08.05.2020 15:07 # 14
BAHTIYAR
my ford taunus had happened to me in my car, nothing came to my mind I called the old owner :) aunt napcam said that the car does not work, turn the ignition to 2, try to miter, continue 2 at the same time, I do not mislead the car. then I gave 25 lira including workmanship, look on the strings, it also breaks with time
08.05.2020 15:07 # 15
I have a brother 206RC vehicle. The same was happening to me every now and then. I completely replaced the wire. only wire costed 85 liras. Do not tire the vehicle too much, somehow it is going to be a bit more like this. Get well soon..
08.05.2020 15:07 # 16
qEccE
my teacher get well soon
the same problem happened to me in the same time there was taunus at the time 2-3 times the wire broke, but there was a motor failure then it was wire break and repeated 2-3 times. You can easily upgrade the gear at 3500 rpm, don't hang out as much as possible :) and the wire shouldn't be expensive in myself. I bought it in 5 or 10 TL for the taunus.
