Emergency braking.
08.05.2020 19:13 # 1
R.CaVuS
Hello friends. When I go downhill with my vehicle (the bottom of the vehicle is very close to the ground), the brake of the car is shaking somewhat and there may be a sound like rubbing under the car.
08.05.2020 19:13 # 2
blntctn
If I think what sounded when the pads were finished, I would not mislead.
08.05.2020 19:13 # 3
KILIC
It shakes my pedal or my car shakes. The disc may be bent or scratched
08.05.2020 19:13 # 4
R.CaVuS
friends do nothing when going downhill on normal road when the vehicle is close to touching the ground. brake pedal swaying.
08.05.2020 19:13 # 5
berk2309
If kickback flickering occurs on the brake pedal, the abs is engaged. If the sudden brake on the steering wheel vibrates excessively when it goes fast, the discs are gone
08.05.2020 19:13 # 6
R.CaVuS
Not because the abs is activated because I touch it slightly. Is there a cable of the brake under the vehicle or something may be rubbing on the ground.
08.05.2020 19:13 # 7
berk2309
It doesn't matter whether you press lightly or press hard, the abs senses itself while the slope is descending, the car's weight is more sensitive than one.
08.05.2020 19:13 # 8
berk2309
If your tires are bad, the room will affect me.
08.05.2020 19:13 # 9
R.CaVuS
No tires are newer. Yes, the brake both goes and backfires. No trouble on straight road. As you said, the vehicle is doing close to touching six places.
08.05.2020 19:13 # 10
R.CaVuS
actual
08.05.2020 19:13 # 11
R.CaVuS
actual
08.05.2020 19:13 # 12
sezar206
My friend, I think the misfire that you mentioned is abs and there is no problem. Since the vehicle enters the abs, either the tires are bad or you have a problem with abs. If you show them to a braker, I think they will find that there is not a very troubled situation.
08.05.2020 19:13 # 13
okaNStarss
I have the same problem in my vehicle, I have no abs, but I have the same problem, the brake pad is kicking back and forth
08.05.2020 19:13 # 14
R.CaVuS
Yes, I took it to the abs industry and showed it :)
