Emergency assistance from masters in P1023-P1025 malfunction
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 20:52 # 1
kelepche
Good Day 2010 Model 3008 My Car's Hose Explosion Resulted In The Engine Has Turned Into Complete Top
CHASSIS NO: AS001802
FLAT GEAR
1.6vti
GASOLINE
While my master was working in peugeot service, he later opened his own shop, but for the first time he encountered such a malfunction.
At least 4 times I know, they removed the top cover and replaced it with that of the engines that work in many parts. Even though it was more than 20 days, the problem was still not resolved.
P1023 was writing, this fault is gone now giving P1025 fault code
I need your help on this
Please keep in mind that opportunistic friends should not call my car to get the price of the dead, even though they have the knowledge to fix the malfunction. AngryClap
TEL: 5309513801
kelepch to 2018-05-07 15:34:24
08.05.2020 20:52 # 2
First of all, welcome to our rigging. I said it is forbidden to write in capital letters as per the forum rules. Of course, get past, my teacher does not have to pay that much and then there is no other problem in the face of such boredom. First of all, to find a master who understands the peugeot rather than the master who has worked for peugeot, who only gets the right to his labor. In such a situation, it really suspects the person if he wants your car at the price I died.
In the meantime, my car is a vti engine or thp motor brother.
Or did they look at these error codes with original software or did they look at my universal error reader device. Because universal devices cannot see some error codes.
As for the problems
P1023 OBD Code Definition:
P1023 Fuel Pressure Control Valve Short To Ground
P1023 OBD Code Description:
Fuel pressure control valve - short to ground
There is a problem in the connections, hoccs, cables, etc. when fixing this
P1025
P1025 OBD Code Description:
P1025 Fuel Pressure Control Valve Mechanical Malfunction
Fuel pressure control valve - mechanical failure
In short, it looks like your vehicle's fuel pump has trouble. Hopefully it will be necessary to find a good master. Of course, we can not say that the pump is defective, perhaps due to a simple non-contact or fuel filter. There are a few contractors on the top and the engine compartment like this. Just like they disassemble the chassis connections while the vehicle is being collected. a lot can happen.
sonerkyl 2018-05-07 14:50:26
08.05.2020 20:52 # 3
kelepche
thank you for your attention:
I came to this master through my acquaintance in another city on the highway while I was going to my hometown.
Also, it is not a master who wants to buy the vehicle without injustice.
one of the registered member of the form site operating in this format
engine vti 1.6 gasoline
kelepch to 2018-05-07 14:59:26
08.05.2020 20:52 # 4
You are welcome brother. Some people I misunderstood are like that bro. Hit the logic of you. If the error codes are examined, the fuel system may be in trouble, there is either an electrical or mechanical problem and there is not enough pressure. If he can, master must be checked with original software, hodja. If I check the engine part well, it may be in a part that does not fit properly.
08.05.2020 20:52 # 5
kelepche
thank you president i hope i can solve the problem
the master could not answer the phone again CryDisapprove
08.05.2020 20:52 # 6
Beyinci_Ugur
6-7-8 of the chassis number. If you write your households, I can help you tomorrow
08.05.2020 20:52 # 7
kelepche
First of all, thank you, UĞUR Ustam
Chassis No: SFWAS001802 If my master does not leave this number, I will try F as P
kelepch to 2018-05-08 10:54:01
08.05.2020 20:52 # 8
kelepche
Can anyone help, at least my request from the forum members Is there any Peugeot master they can recommend in Adana?
21.12.2025 15:52 # 9
community
How can I contact you? Please get in touch.
12.01.2026 00:55 # 10
forumcu3
Can I get recommendations for a mechanic in Ankara who understands Peugeot 3008? data-cf-beacon="{"version":"2024.11.0","token":"11ac6a036a5c4b83a3c20a30a3bc3ba2","r":1,"server_timing":{"name":{"cfCache Status":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true},"location_startswith":null}}" crossorigin="anonymous">
