Emergency assistance for Peugeot 307 1.6 HDI
08.05.2020 20:17 # 1
kursuni
Hello friends car 2006 307 1.6 HDI premium.
I made about 1300 km three days ago, I came to Ankara. I parked the car one day later I wanted to run it does not work.
I am burning the ignition of the vehicle, only the "oil ok" text and the maintenance mileage were on, but now it is not on and it gives a warning signal when I turn the ignition.
Can you help me. Thanks
08.05.2020 20:17 # 2
kursuni
If you are familiar with the Peugeot master who can recommend honestly and knowledgeable in Ankara, please help.
Thanks in advance.
08.05.2020 20:17 # 3
Get well, no teacher, no starter.
08.05.2020 20:17 # 4
GokhaN
I think the problem is on the battery
08.05.2020 20:17 # 5
kursuni
Thank you sonerkyl
It sounds like there is no starter at all, and there is a warning signal behind it. Why do you have a big one? Meanwhile, the battery was installed for a week.
08.05.2020 20:17 # 6
If your teacher is new, I think the problem is at the starter
08.05.2020 20:17 # 7
Ege Mavisi 206
At the weekend, I also traveled 500 kilometers, stayed in the city while traveling. There is no warning etc. when the ignition is turned on. There is no click when you turn the anthem. We tried to hit him, we took him to the electrician. they changed the starter coal problem was solved. There are those who say starter automatics, coal can run out, and the collector can burn. He put the vehicle in 1st gear and made it slightly back and forth. Maybe if I say if the starter motor is attached or something. If you want to do it like hitting back and forth slightly, maybe if there is a jam in the starter, there will be a remedy, or if the starter coal is old, go and show it to the electrician directly.
08.05.2020 20:17 # 8
kursuni
Thank you guys, let's take a look at the starter motor, hopefully there is no other problem
08.05.2020 20:17 # 9
KILIC
The battery seems to be exhausted. If your mind is new, I agree with my soner teacher. SWORD 2017-04-06 15:25:51
08.05.2020 20:17 # 10
kursuni
Could there be a problem with the fuse because the radio and multi information does not open on the screen
08.05.2020 20:17 # 11
KILIC
If the battery is dead, it is normal for them not to work. Check the charge dynamo.
08.05.2020 20:17 # 12
kursuni
Thank you, KILIÇ, the industry is good at the weekend.
08.05.2020 20:17 # 13
kursuni
Friends I checked the battery indicator, I shot a small green video, I hope the problem can be understood better.
08.05.2020 20:17 # 14
ggitaristt
The same thing happened to me, I tried with reinforcement and worked. I went and bought a new battery.
