(Emergency Assistance) 307 starter problem !!!
08.05.2020 14:59 # 1
endorphine
My car 2006 model 307 comfort automatic transmission. When I start, the engine sounds like it will turn, but it does not start. In the video below, that sound cannot be heard because of the warning sound. There is an error message on the screen but it says seat belt or airbag. I think it's an irrelevant warning. If I say the battery is dead, headlights etc. things are working normally. I would be glad if you could help me as soon as possible.
http://www.youtube.com/watch?v=r57jıhoohkc
08.05.2020 14:59 # 2
endorphine
If I do not get a result today, I will have to call the authorized service tomorrow. Lightning auto closest to me. Let's see how many hundred TL they will compress the engine :(.
08.05.2020 14:59 # 3
okan77
It may be the starter motor ... The only chance to start it is ... The room is not good ... Does the tape work and the indicator lights come and go when you start?
08.05.2020 14:59 # 4
okan77
Did airbag default ever written
08.05.2020 14:59 # 5
emin15
Since the vehicle is automatic, you cannot hit it. airbag s-belt is a seat belt warning. consideration. battery causes problems in cold weather. try reinforcing from another vehicle. it will probably work.
08.05.2020 14:59 # 6
Don't hit the mate, buddy. your problem is definitely possible in starter motor repair
08.05.2020 14:59 # 7
Onur
automatic vehicle does not hit or run, it seems like a problem caused by the battery.
08.05.2020 14:59 # 8
ugur
Do not deal with anything else that is definitely out of battery, the sound of the battery warning sound will not start when the battery is weak.
08.05.2020 14:59 # 9
endorphine
Work power ... I couldn't find time to write a message. The incident is accumulator friends. I changed it, it improved. By the way - the pole had become unusable from the oxide formed by vomiting the battery, I changed it. The originality is gone, but no more.
