[Emergency Assistance] 206+ Plus Brake Presses Sound. |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 206+ | |
| 08.05.2020 14:11 | # 1 |
| 08.05.2020 14:11 | # 2 |
Is it like a bird sound when you say tickler? The same problem happens to me sometimes, especially after the rainy weather.
| 08.05.2020 14:11 | # 3 |
may be caused by pads or disks
| 08.05.2020 14:11 | # 4 |
lining cleaner sprays often nothing
| 08.05.2020 14:11 | # 5 |
No, I'm sitting in Ankara, already, the rain is not even a true snowfall Nerdee :) Just like you said sounds sound like bird sound. Korkum Balata Ending: Q But Is The 4-Month-Old Car's Pad Ending Immediately?
| 08.05.2020 14:11 | # 6 |
Your pads may be finished. Or, their discs may be skewed or run out. |
| 08.05.2020 14:11 | # 7 |
If the ax of the 4-month-old car runs out, it will be scrapped after 2 years: S
| 08.05.2020 14:11 | # 8 |
The car is just 4,000 km.
| 08.05.2020 14:11 | # 9 |
If you think the pad is not finished, you can guess it because you are using it for yourself. I will do the same.
| 08.05.2020 14:11 | # 10 |
At 4,000 km, the car's pad will end and they will have to look at it.
| 08.05.2020 14:11 | # 11 |
guaranteed car ,, dirt entered the pad .. they send a cleaner ..
| 08.05.2020 14:11 | # 12 |
okan77 |
They couldn't solve this problem in 207 either ...
| 08.05.2020 14:11 | # 13 |
cerci07 |
I think they are using hard pads, so I think there are 206 I have pejo so far, whatever problem the guys will do if they do it smartly, where do they get the money? img src = "smileys / smiley7.gif" border = "0" alt = "Frustrated" title = " Frustrated "/> |
| 08.05.2020 14:11 | # 14 |
that problem is also with mine. I went and bought bohs' s pad. I changed it & nbsp; still & nbsp; there is; mine is doing it in dry weather
| 08.05.2020 14:11 | # 15 |
they spray and send it to the liner .. Probably the dust has escaped .. Other than that, the pad ends at 5000 and 50.000. This is not a major problem, don't bother.
| 08.05.2020 14:11 | # 16 |
t@lip |
I replaced the pads 10-15 days ago, the discs are not bad, there is also a slight whistling sound that comes with the brake in my car. I ride by whistling.
| 08.05.2020 14:11 | # 17 |
[QUOTE = kundun] there are cleansing sprays for pads often nothing is left [/ QUOTE] & nbsp; & nbsp; Exactly .. nothing is left with the spray. < / DIV> Worst case is you replace the brake pads
| 08.05.2020 14:11 | # 18 |
Probably because of dust, there is sound. I have been using 206 + 1.4 petrol since November. I am really pleased. I overturned 7500 km
| 08.05.2020 14:11 | # 19 |
