Emergency aid to 307 transmission
08.05.2020 19:59 # 1
jpm06
2004 model 307 otm. I have the car
Today, when I asked, I had a problem, the car yelled as if another boot was over, but it was not going.
In the evening, I showed it to a master and it cost me 4.5 cards. Tomorrow I will go to the eagle auto industry, but I am looking for a competent master
08.05.2020 19:59 # 2
talip206
The transmission probably protected itself. When taken under protection, the gear takes 3 gears and for this reason, as soon as you yell out. It improves when the ignition is turned off and on. Such malfunctions often result in Solenoid failure, which adjusts the transmission oil pressure. The estimated cost is between 600-800 TL with gearbox oil, two Solenoids and workmanship. In other words, do not believe those who say that they will get down immediately. Go to the gearbox master, not the normal engine master. The healthiest result comes when you connect it to the computer. Search for automatic gear fault and transmission malfunctions in the forum
08.05.2020 19:59 # 3
jpm06
Well, teacher, I can control the gears by myself, as I said, the car is moving as if the pressure pad is over.
08.05.2020 19:59 # 4
jpm06
The result of the vehicle is clear 4200 TL :(
08.05.2020 19:59 # 5
talip206
[QUOTE = jpm06] The result of the car is certain 4280 tl: ([/ QUOTE]
Get well, why was the problem caused?
08.05.2020 19:59 # 6
jpm06
The filter is clogged, teacher.
