emergency aid steering was like stone.
08.05.2020 20:15 # 1
JunioR56
firstly hello everyone
I have a 2003 model 307 xt gasoline vehicle. when I turned the steering wheel to and fro, it sounded foggy, as if oil was mixed with air through the hose. I went to the shell and asked for steering oil. They gave me atf automatic transmission oil, the color of the oil was red. I hesitated not to take it. "We are using it constantly," he said.
I poured the oil a little too much, I did not see the max line on the stick. sound stopped for 10 days there was no problem. I ran it 3 km today and stopped, I ran it again like a stone. I went for another 5 km and when I opened the bonnet hardly, I saw that oil was pouring out of the small hole on the steering oil cover. When I first started it 6 months ago, the steering wheel got harder but it returned to normal after 2 or 3 minutes. Frankly, I saw that the oil did not soften today and I saw it. what is your opinion
thanks in advance
08.05.2020 20:15 # 2
BLACK LION
I suggest you first show a master whether your problem is from the electrohydraulic steering motor or something else. Do you have a jiggle? But steering oil is not put in that way. Drain the steering oil completely. Someone will wait little by little and you will make left and right tours. Otherwise, since the oil cannot be settled easily, it can also make air gaps and overflow when it becomes hot and later expands. Neither missing nor more, it is put up to the line, no more. As I said, show it to the master first.
BLACK LION 2017-03-19 15:09:54
08.05.2020 20:15 # 3
ismailkaya
These troubles appear when the vehicle turns the steering wheel left and right in a stop. I think it is making air in the pump or it may have lost its oil property. If you want to go to the steering wheel and change the oil
08.05.2020 20:15 # 4
JunioR56
I took the oil level of the vehicle with a handkerchief like 3 noon and brought it to its normal value. I cleaned the poles with sandpaper and checked the fuses. An 80 amp fuse was loose under the fuse box in the engine, and I fixed it and started the starter. We went to the guesthouse at 8 in the evening, there is no problem. I feel upset. what could be the problem mechanical or electrical or simpler?
08.05.2020 20:15 # 5
The problem of the teacher is the oxidation of the steering pump's electronic gutters makes it more frequent on rainy and humid days. Unfortunately, there is no solution other than repair or replacement. Also, disassemble the fuse box and look inside, it can cause such problems in oxidation.
08.05.2020 20:15 # 6
JunioR56
I ran it today it improved again. I ran it many times, it was not broken. my guess was that the gearbox oil was filled after the master repaired the axles. they pressed a lot of oil because they could not see. oil was flowing down considerably. probably came to the socket too, and this problem arose. I was bored at first but I got used to it now my brother is hanging out around :-)
I hope it will not repeat.
08.05.2020 20:15 # 7
JunioR56
Dear forums.
I am writing the subject to get the information if there are people with current problems. Do not put the steering hydraulic oil too much because it discards more than the cover and the flowing oil is filtered and filled into the energy and data sockets at the bottom of the tank. I said I could not look at the oil of the running steering wheel and added oil a little more, the steering wheel was broken again. I disassembled the pole and slept under the car and cleaned the sockets beautifully. I reattached and operated the pole head, the steering was still stiff but extra dan
ABS, ESP, AIRBAG, KM INDICATOR did not work. When I checked the trip computer, even while walking at the walking speed, instant consumption shows 30 liters and did not count how many kilometers of the road I went.
I think I ate it completely as I tampered with the electronics.
I cleaned the poles with sandpaper so that there was no problem with electricity, I cut copper wires between the latch and pressed them in order to press them firmly.
I will travel 200 km tomorrow and I hope it will be improved. The divide made several mistakes (excluding km errors) and improved as the pole tampered. I hope it gets better.
08.05.2020 20:15 # 8
JunioR56
The whole problem is from potential pole heads. In my vehicle, you pinch the terminals of the battery in the form of a ratchet, and it causes trouble not passing the electricity easily. Again, I read in the forum that if the electricity does not come in a healthy way, the brain protects itself and shuts down everything. Last night I pressed the battery to disassemble it, saying that if it breaks, it will break. I started the car in the morning and returned to normal.
I present to the information of friends who have problems.
