EMERGENCY AID PLEASE !!!
08.05.2020 16:40 # 1
tariik_akan
Hello;
Peugeot 307 1.6xr & nbsp; I have a 110 hp sw vehicle. then it was pouring from under the full clutch of oil like oil. I changed the clutch pressure pad of the car 1.5 years ago. The car is not going into gear at all. Why do you think? Please help. Thank you in advance ... I asked the master, clutch print will change the pad 450 tl money Did he wonder if he did?
08.05.2020 16:40 # 2
furkan111
450 pads for printing pad. Also, when you changed the printing pad 1.5 before, did you replace it with the original? ?
08.05.2020 16:40 # 3
tariik_akan
No, I had a byproduct in the industry again. I am married, I am facing such difficulties just above marriage. The clutch is kept pressed up to the bottom even though it is stuck in the water.
08.05.2020 16:40 # 4
furkan111
Check the engine oil and water of your vehicle. If these are normal, it is the flowing grease. So how was your gear shift, especially 1 and reverse gears.
it may be in the drain wire.
& nbsp;
08.05.2020 16:40 # 5
tariik_akan
Look at the engine oil all was normal, there was no shortage of water, but before that it was going to go to 1st gear.
08.05.2020 16:40 # 6
furkan111
As the master says, the great pressure will change the pad ... the average should be 400 including the original thing, not more than 400. I changed it to 300 206's
08.05.2020 16:40 # 7
tariik_akan
Now I am searching on the internet, some of them said 258 TL, I found in luleburgaz in kirkeleel.If I will call around 150 TL, I will call tomorrow, if you need to go from there and take the price directly in the industry. I got over it. But such high expenses scare me a lot. I'm trying to set up my nest.
08.05.2020 16:40 # 8
furkan111
Make sure you buy another car, the room will cost you and I will suffer it. Best of all, you know the water you have. You have the problems you get. It is very weak like giving you the same problems. Be alongside mumkunse assembly, very knowledgeable.
I changed my own master in the industry.
08.05.2020 16:40 # 9
furkan111
If you are going to get it from the internet, I recommend it and give it the number of the number, then the wrong track will be less. There are two types of sets that I know because
now the masters are robbing the man. If you know how many times I have witnessed this!
is going to buy a piece of the piece, how much money, say, say, 300 lira, 50 lira, and then it says 350 pieces. He takes two or three shops away from him ... or he orders the room from the net, he adds it again, including the shipping money. As already known, the labor prices are too high.
it is as if we find the money on the street. He wanted to lose it, but the spark plugs are 20 lira.10 lira, no matter if it gets profit ... I had a fight with the man, even what he wore could not get back. God bless us all from such masters
08.05.2020 16:40 # 10
tariik_akan
no, no, I don't leave my life, I don't have the desire to leave the press. I stayed in the industry for 8 hours once, but in the low voices, but I still did not leave the vehicle from the press. I also have an installment. The service wants a lot of money. I got a check up at the service. I took out the cost of 1.250 TL. I got the list. He wants 20 TL for 5 pounds of service. If we know it, we will make it, but he must comply with our account.
08.05.2020 16:40 # 11
tariik_akan
I say I get it from the internet, but I can't trust the credit card information, what do you give? .If it will fit, I will give you the number of the number. I said that the service was 800 TL, including workmanship and the brain is nowhere, they said we will come from France. headlight flashing 4s calist down wipers Angel rings were not burning etc. I will go to Antalya in summer, I hope it will not cause any problems.
08.05.2020 16:40 # 12
furkan111
A plus of the service guarantees so much.
but I don't mind bothering me 6 months ago I had a palio 98 model authorized service even asked 650 for its printing pad. I went to 250 I made it in the industry. I usually do.
08.05.2020 16:40 # 13
tariik_akan
Yes, it may be a solution. I'm right. I will search for the piece in detail tomorrow. I will find the piece. When the day is clear, I will thank you again for your help.
08.05.2020 16:40 # 14
furkan111
yes, you are right, I do not trust anybody. If you would like to have a look here.
08.05.2020 16:40 # 15
furkan111
What do we mean, we, as pugcular, should support each other. Thank you. I will help you if you want yalova. Goodnight
08.05.2020 16:40 # 16
istanbullu_3886
[QUOTE = date_akan] I say I get it from the internet, but I can't trust it. I don't give credit card information. I can give it the number of it, if I can get it out of the hand. It hurts. I have to rush from the others. The service said 800 TL, including labor and the brain is nowhere, they said they will come from France. He was opening his windows. the angel rings were not burning, etc. summer, i will go to antalya, i hope it won't be a problem. it will not be put on the road ... [/ QUOTE] bsi you can have your brain repaired, this service said this brain is new 800
08.05.2020 16:40 # 17
Your master may be right, but not 100%. My guess is that your problem is due to the skip of the master or slave cylinder. Be sure to look at these before replacing your print lining, or you will give master / slave cylinder money, since both print lining money will not go away. It seems to me that the clutch pedal is flowing just under it, it seems like a possible master cylinder failure. Reviews
08.05.2020 16:40 # 18
tariik_akan
Thanks for your help, thank you very much. The problem has been solved. I did not give money. Also, his brain passed to repair, a professiynel master need it. Because he kuf captured. The new service said 800tl.
08.05.2020 16:40 # 19
Cmoss06
Get well
08.05.2020 16:40 # 20
tariik_akan
Yes, friends, I have smoothed the pc and I am in front of you :) Thank you to Furkan for your help again. REMOVED FROM WEAR.When an iron hose was left with all hydraulic oil drained, the transmission clutch was oil-free. He asked me to pay 50 TL for workmanship fee. I had to buy it from the industry because I had an urgency. "smileys / smiley1.gif" border = "0" alt = "Smile" title = "Smile" /> & nbsp; changed the hose. put the hydraulic oil. pumped a little clutch After running, and the vehicle was going into gear. The problem was resolved. I came to a master master, he came up to him, he took it off, he took a 50 TL workmanship fee. There was no clutch wire. It was a different system. Anyway, I couldn't extend it any more. Respect everyone, thank you. Thank you all.
Page : / 2
