EMERGENCY AID PLEASE
08.05.2020 19:39 # 1
Pug106
Hello everyone,
First of all, I opened the subject that I will open now, now my problem is this:
My vehicle 106 XR 1999 1.4 MOTOR
MY CAR IS BLASTING ON THE ROAD ON THE GAS, GAS ON THE ROAD, I WAS NOT CONNECTED TO THE TUTE IN THE FULL GAS, AND I HAVE NOT SURVED THE LIGHT ON THE DISPLAY AND I HAVE BEEN WHICH I HAVE BEEN WHEN I HAVE BEEN OXIJEN ...
08.05.2020 19:39 # 2
TugyyStyle
There was a problem of not eating gas in the gas butterfly.
08.05.2020 19:39 # 3
Pug106
Master Says Clean I Do Not Understand Gone
08.05.2020 19:39 # 4
Pug106
Any Other Idea Please Waiting For Help.
08.05.2020 19:39 # 5
childrenofgrave
Is there late work on the vehicle, especially in the morning? childrenofgrav to 2016-02-12 00:25:41
08.05.2020 19:39 # 6
Pug106
No Single Takes At Idle, Good Fluctuation etc. Conditions Not Frequent Does Not Do After 5 Minutes Estimated Drowning Gas Last Gas Bassam Flies On The Road What Do I Know?
08.05.2020 19:39 # 7
Pug106
I did a reset to the brain. I say the same again. Oxygen Sensor?
08.05.2020 19:39 # 8
childrenofgrave
I think that if the oxygen sensor was defective, the malfunction lamp would have turned on. Of course I had a stylo, he used to burn it. I don't know if it doesn't burn in these. In addition, I remember that the oxygen sensor does not have any visible problems in the vehicle, as well as the excess fuel consumption. Since there is a problem in both gasoline and LPG, the gas pump option is also not suitable. The problem is related to electronics or ignition.
What you call drowning isn't kicking, is it?
08.05.2020 19:39 # 9
childrenofgrave
Still, listen to the air filter box, hoses and intake manifold. See if there is an air leak with sound and visual. If you have not cleaned the throat butterfly nearby, clean it. It may also be useful to remove and clean the map sensor. You can clean the sockets of this sensor and the butterfly with oil-free contact spray. Sometimes such problems can also be the source of such problems. If these don't work, it feels like throat butterfly, coil and spark plug.
In the meantime, masters who cannot get out of this kind of problems directly say "brain". I don't believe it. Look for another master. You can go to Bosh Car service or authorized service.
08.05.2020 19:39 # 10
koray.turan
I had the same problem, the coil came out, the trouble in me
08.05.2020 19:39 # 11
Pug106
Ok, brother, I will do exactly what you say, thank you very much.
08.05.2020 19:39 # 12
childrenofgrave
[QUOTE = Pug106] Okay, brother, I will do exactly what you said, Thank you very much. After Friday I will go to the Master, Come on, Good Luck [/ QUOTE]
I hope you have solved the problem. I would be glad if you share the result.
