EMERGENCY AID PLEASE
08.05.2020 20:08 # 1
Erdi1686
Thank you guys for your help in advance ...
I have a 2001 model roland garros vehicle, two days ago, I had the hydraulic hose oil leak. Meanwhile, the end of the heat, the customer is defective, he changed it, it was connected to the PC again, the vehicle has been dealing for the same two days.
I will recommend someone who understands the job from the bursa, otherwise I will burn the car because of the people who do not know the job
08.05.2020 20:08 # 2
First of all, welcome to us. Disable the lpg system, disassemble the fuse, whether the vehicle is in gasoline and whether there is no gasoline under the quarter tank, let's see if the pump of the diaper is working. Have ecu (motor) sockets checked for oxidation etc. Have a look at the kran cycle (position) sensor. the battery was dismantled while the vehicle was being repaired. coil and spark plugs checked.
