Emergency aid nobody could solve ...
08.05.2020 19:20 # 1
Sertac
I have 97 peugeot 106 xr friends. No matter how skillfully I got my car, it couldn't solve the problem. Your vehicle is not officially leaving. As if pulling 3 people from behind. The slopes 1st gear is getting harder. What can be boredom? Please help me. sertaç 2015-06-21 21:52:19
08.05.2020 19:20 # 2
samet206
Press Balata, Akslar, Ignition system, these are examined.
08.05.2020 19:20 # 3
srdrgktp
Hi
If there is a crankshaft sensor, if you want to have a look at it .. 2000 106 gti and 2006 206 1.4 HDI also happened to us.
08.05.2020 19:20 # 4
cihanusta
If your vehicle is automatic, definitely look at the transmission system
08.05.2020 19:20 # 5
Sertac
Friends, I just replaced the spark plug and spark plug wires. I checked my print. My vehicle is gaseous but there is a problem. We couldn't figure it out. The vehicle is not automatic sertaç 2015-06-22 10:41:49
08.05.2020 19:20 # 6
peugeot murat
Contact me on 05358461001 let's talk
08.05.2020 19:20 # 7
Sertac
Thanks everyone, I went to the master, looked at the timing sent setting, it turned out normal. It looked normal whether the exhaust was blocked. I hope he will look at the latest sibob setting tomorrow. If he doesn't show up in him, our job is bad.
08.05.2020 19:20 # 8
ismailkaya
If the vehicle is working normally or what's the problem with the bottle, it works with a different sound, do you decrease the oil? I think circulating piston bearings or clutch plate or alternator
08.05.2020 19:20 # 9
peugeot murat
I passed everything I couldn't understand what altarnator was
08.05.2020 19:20 # 10
Sertac
There is no sound in the engine, there is no slightest problem in starting the car.
08.05.2020 19:20 # 11
Sertac
My car had a problem with the Sibob setting. sertaç 2015-06-23 23:31:38
08.05.2020 19:20 # 12
peugeot murat
[QUOTE = Sertaç] Sibob setting behave, the vehicle has a problem has improved:) [/ QUOTE]
Have your eyes lit
08.05.2020 19:20 # 13
Sertac
Thank you bro you really helped
08.05.2020 19:20 # 14
peugeot murat
I was naap, I did not even touch my hand, I shared information, if I could help, how happy
