emergency aid masters
08.05.2020 16:48 # 1
falan
slm friends .. In the morning, the temperature rose, I opened the hood, the water was reduced .. I filled the water & nbsp; I dvm up to the workplace (5 km), then I got out of the vehicle and looked at it from the bottom, dripping water. why do you think? Would he fill the water again in the evening and take him to the repair shop?
08.05.2020 16:48 # 2
Bugra
you may have pierced the radiator. If you buy a 5 liter can and check it, you better go to the master.
08.05.2020 16:48 # 3
metin
Did you see exactly where it was dripping from?
08.05.2020 16:48 # 4
falan
if we pierce the radiator, it will explode to us
08.05.2020 16:48 # 5
metin
If we pierce the [QUOTE = or something] radiator, it explodes to us [/ QUOTE]
First we need to find out where the problem is. It may also be a radiator, it may be one of the hoses, it may be in a thermostat etc. & nbsp;
If you first find out where it flows, the solution will be quicker.
08.05.2020 16:48 # 6
falan
yesterday the master said there was no oil cooler in our cars .. ?? He said that it may have burned a gasket mixed with oil in the water .. I left the car today and said that half of the engine will be dismantled .. 500-600 amount said :( I had to compel it. But he looked at the engine last night.
08.05.2020 16:48 # 7
falan
2000 & nbsp; mod 206 xr petrol l, is there an oil cooler_
08.05.2020 16:48 # 8
sahin-peugeot
there is no oil cooler in your vehicle
08.05.2020 16:48 # 9
falan
thank you & nbsp; for cvp
08.05.2020 16:48 # 10
206206
get well soon & nbsp; & nbsp; 500-600 & nbsp; very & nbsp; money or & nbsp; i hope it doesn't keep up & nbsp; & nbsp; in another master you had shown. probably the & nbsp; can be hose & nbsp; & nbsp; I think the & nbsp; Winter & nbsp; Write to & nbsp; transition in & nbsp; Hoses & nbsp; Can Çatlı. radiator & nbsp; & nbsp; unless hit Easy & nbsp; Easy & nbsp; does not leak
08.05.2020 16:48 # 11
metin
[QUOTE = or something] our cars didn't have an oil cooler yesterday the master said so .. ?? He said it may have burned oil-mixed gasket in the water .. I left the car today and said that half of the engine will be dismantled .. 500-600 amount said :( I was obliged. But he looked at the engine well last night. QUOTE]
Have you entrusted your vehicle to a master who doesn't know if there is an oil cooler when he looks at your car, but can immediately understand that the top cover should be opened to earn money?
08.05.2020 16:48 # 12
[QUOTE = text]
Have you entrusted your vehicle to a master who does not know if there is an oil cooler when he looks at your vehicle, but can immediately understand that the top cover should be opened to earn money?
A sensitive point "Ermm"
koliva 2012-05-24 11:53:38
08.05.2020 16:48 # 13
falan
only & nbsp; 1 master, not 3 masters, among them, they asked if there was an oil cooler or not, they went back and forth. The water in the canister had reached the consistency of tahini .. so he missed the obvious oil ... could there be another reason for oil to get there? & nbsp; I was always afraid to even run the car to show the master I went to elsewhere ..
08.05.2020 16:48 # 14
metin
[QUOTE = or something] our cars didn't have an oil cooler yesterday the master said so .. ?? He said it may have burned oil-mixed gasket in the water .. I left the car today, half of the engine will be dismantled. QUOTE]
those transactions cost up to 350 TL including labor. & Nbsp;
08.05.2020 16:48 # 15
simirnoffredbull
the same thing happened in me antifreeze suddenly discharged. took me to the industry they looked & nbsp; thermostat water distributor cracked replaced. piece 160 tl workmanship 40 tl opet organic antifreeze kept 30 tl
08.05.2020 16:48 # 16
falan
[QUOTE = simirnoffredbull] same thing happened to me antifreeze suddenly empty. piece 160 tl workmanship 40 tl opet organic antifreeze kept 30 tl
did the color of your antifreeze come to the consistency of tahini? Mine was in the consistency of tahini after pouring water on it
& nbsp;
08.05.2020 16:48 # 17
falan
Now I went to look at the car. they have lowered the engine, stoned, they will be replaced tomorrow .. & nbsp; if we come from where the problem originates .. pipe under antifreeze cracked & nbsp; I did not notice the car in the morning until morning, I did not notice the situation in all morning rush, & nbsp; I'm on the way .. on the way & nbsp; heat & nbsp; When do & nbsp; I opened the hood and looked. the water was over, I filled the water and dvm the road, of course, the water I filled was drained from the crack in the road .. & nbsp; so we burned the gasket .. i hope i will buy the car tomorrow it will not hold much .. be you do not fill the car with the overheating car ... & nbsp; This is a lesson for us .. May God not cause any trouble. May your prayer be blessed
08.05.2020 16:48 # 18
safrane23
Make sure you have 70% antifreeze in your vehicle.
08.05.2020 16:48 # 19
falan
[QUOTE = safrane23] Get well and have 70% antifreeze in your vehicle .... [/ QUOTE]
already had antifreeze
08.05.2020 16:48 # 20
pug61
If there is lubrication in the water reservoir, I recommend you to check the consistency of the engine oil at a high probability that it will be from the cylinder head gasket & nbsp;
Page : / 2
