Emergency aid information for 5008 automatic gear failure
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 5008
08.05.2020 21:13 # 1
Abdulmelik
first of all greetings to everyone i just joined you
I bought a 2010 model 253000 km (5008)
Due to my job, I can only use the vehicle on weekends
14 days after I bought the vehicle, I also stashed it empty, I tried to run it the next day, the vehicle is holding itself in d1 whereas the gear lever was also called the tagmirci, I erased the device with the device and removed it from the brain, removed it with a spray and replaced it.
A few weeks later
The car made the same fault again after a few uses, I called the same master again, and did the same operations and bring the car to the shop for the fault, let's see the socket electrical installation malfunction.
I did not take it from hard work this time, Birgül entered the strange states such as the first time on the road, charging was cut, I pulled it to the appropriate place, did not work, took it to the automaker with the tractor, they were interested in the car Monday, when the car produced more charge than the car,
The automaker said that he did it because of this electrical failure and I took the car and came home a week later I used the car, this time he took it empty and stopped, he was fixing it when he ran it two or three times, and he came home again, I closed the car, they looked and looked, the gear that changed the pressure of the robot or whatever the name is. He said it was defective, then said the brain, now I'm surprised by whom to believe
Does anyone know about this?
Or can you help CryCryCry
08.05.2020 21:13 # 2
My advice is to take your vehicle to the authorized service and have it determined exactly what the problem is. it costs no more than 150-200 TL. But you will find out where the problem is with a 80% probability. Accordingly, you replace the part that needs repair or replacement in the industry.
08.05.2020 21:13 # 3
Abdulmelik
I hope we started working with a service that is very original software, and I guess I will share an accurate master result with you.
08.05.2020 21:13 # 4
I hope your problem will be resolved at an affordable price.
14.07.2021 22:28 # 5
Arda5008
Hello, my vehicle is 2011 model 5008 at 80 thousand km, about 1 hour after starting the air conditioner, the gearbox malfunctions. When you turn it off and on, it continues to work, but without turning on the air conditioner. We put it in the machine, it did not show any malfunction. There is no other problem in the vehicle, everything is complete, has there been a problem with the air conditioner in this way?
