Emergency aid heater fan (SOLVED)
08.05.2020 17:15 # 1
leventturksoy
First of all hello friends I just joined the form & nbsp; I read really useful information
thank you all & nbsp; "r" = "" style = "padding: 0px; margin: 0px; overflow:; text-overflow: ellipsis;"> heater fan & nbsp; running & nbsp; turning off from digital display but not turning off
heating cooling is showing the entire display of digital display & nbsp;
I think the heater fan is stuck. I inserted the battery pole, I installed it.
the problem runs until I stop the same car < span>
Where is the 207 central heating fan? 2013-01-15 15:47:13
08.05.2020 17:15 # 2
deme
http://forum.peugeotturkey.com/forum_posts .asp? TID = 13589 & amp; title = radiator-fan-motor with -arzas
08.05.2020 17:15 # 3
leventturksoy
[QUOTE = don't say] http: // forum. peugeotturkey.com/forum_posts.asp?TID=13589&title=kalorifer-fan-moturu-arzas [/ QUOTE]
brother thank you & nbsp; i read that topic there tool 206 & nbsp; i am talking about 207 & nbsp; none friends
207 & nbsp; radiator fan & nbsp; I don't have an official stuff that knows the location of the engine friends
08.05.2020 17:15 # 4
Serkan
Hodja, the # 2 fan motor in the picture, I couldn't get a precise location, but I think behind the front chest, you can reach it by the accelerator, it is probably in the same location as 206
< editID> Serco05 2013-01-05 00:39:21
08.05.2020 17:15 # 5
leventturksoy
[QUOTE = Serco05] Hodja, the number 2 fan motor in the picture, I couldn't get a precise location, but I think behind the front chest, you can reach from the side of the accelerator, probably in the same location as 206
sagolas & nbsp; tomorrow bakcam first name & nbsp; insallah is the same & nbsp;
08.05.2020 17:15 # 6
Serkan
The picture above is my 207 teacher, as I said, I couldn't see the exact picture, but probably the upper right side of the accelerator pedal
08.05.2020 17:15 # 7
leventturksoy
[TUBE] S8s7DrcegDQ [/ TUBE] [QUOTE = Serco05] Sir, the number 2 fan motor in the picture could not be precisely located, but I think behind the front chest, you can reach the side of the accelerator, probably in the same place as
I want to see your brother, I want to see you :) :) I don't think it would be the same thing. 206 for friends
[TUBE] http://www.youtube.com/watch?feature=player_detailpage&v=S8s7DrcegDQ [/ TUBE]
leventturksoy 2013-01 -05 03:55:15
08.05.2020 17:15 # 8
Serkan
He was in the same place with his teacher 206 & nbsp; In the link given by a friend above, they removed the engine from the gas pedal, but to remove it, it was necessary to remove the steering knuckle.
08.05.2020 17:15 # 9
leventturksoy
[QUOTE = Serco05] He was in the same place with his teacher 206 & nbsp; In the link given by a friend above, they removed the engine from the gas pedal, but to remove it, it was necessary to remove the steering knuckle. [/ QUOTE]
thanks hacam & nbsp; I will be able to insert the plug of the trip computer and plug in the cord, I am an electronics engineer, I don't think there is any malfunction.
08.05.2020 17:15 # 10
leventturksoy
[QUOTE = leventturksoy] first of all hello friends I was new to the form I really read very useful information thank you to my team Let's come to my problem my vehicle 207 digital air conditioning my friends run my car, I do not start it, I turn off the cooling fan, I turn off from the digital display, I do not turn off from the display, but I do not turn off from the display, the heating is switched off from the digital display, the heating is switched off, the heating is switched off, the display is switched off I got it plugged in. If the problem is running until the car stops, I am an electronic engineer. I inserted it, I couldn't reach it, then I inserted the enclosure next to the gazpedal, it was inserted very easily. They put only one screw, they did not install 2 screws, it was difficult to insert the vehicle, since it was difficult to insert it, they did not install 2 screws. With the help of a resistor air gun and soldering iron for the lecture halls, I changed the student and tried it. The malfunction was broken. If this is done, these are my own observations from this partUploaded with ImageShack.usparca this is exactly one
08.05.2020 17:15 # 11
Serkan
Thank you for your information.
