Emergency aid. Glass release buttons have failed
08.05.2020 21:21 # 1
erhan78
HI FRIENDS. I am a 308 user for about 4 years. THERE WAS HAPPENING WHEN I SET THE MIRRORS OF MY VEHICLE FROM THE LEFT DOOR CONTROL. Since I HAVE HIS SOME HORIZONTAL I HAVE REMOVED THE KEYBOARD AND CLEARED THE GOLDEN KNOW OF THE MIRROR KEYS AND REPLACED IT ON THE SITE. KEYS WORKED BUT THE GLASS OPEN CLOSE KEYS HAVE A SOMEONE 😟 REMOVE PLUG, REMOVE PLUG, OTHER WINDOWS ARE NOT OPENED, EXCEPT THE DRIVER SIDE OF THE KEYPAD 😢 THE WINDOWS WILL NOT REMOVE THE GLASSES AUTOMATICALLY. When I look at the booklet, it protects itself and a management locks up and says it will fix, but mine did not. I MAKE SURE THE KEYPAD IS STURDY. I HAVE A DIFFERENCE IN A PLACE, BUT I DID NOT SOLVE IT. MASTERS NEED TO CHANGE THE DIRECT KEYS WITHOUT LOOKING AT ALL. BUT THERE IS A ROOM TO CHANGE WHEN THE KEYS ARE CHANGED. THERE ARE VERY KNOWLEDGE FRIENDS HERE. HOPE ARE FRIENDS TO HELP. THANK YOU VERY MUCH NOW. & Nbsp;
08.05.2020 21:21 # 2
omerb
hi, if you are sure that the keys are working, did you short circuit while cleaning. Because if the key is broken, I think it won't prevent you from opening and closing the window from the remote control.
Check the fuses.
Think again about what you did to the keys, there is no cable contact. Will the cables come out of the socket lightly from the socket part one by one. I say check it out.
08.05.2020 21:21 # 3
erhan78
Insurance came to my mind. If there is a short circuit or fuse that I don't understand, single glass and mirrors won't work either. But the mirrors and child lock work on the key. But only the other 3 windows are not working. Disabled in automatic lifting of the windows from the remote control. There is a setting for this, but no one understands. There is no shuttle service in my city. He says nonsense to the masters. I hope a person who understands
08.05.2020 21:21 # 4
omerb
I found the following information somewhere. If you want a try. It was a glass reset for 307. I don't know if it will be at 308. Try this on working glass too I think
Lower the glass completely, then press and hold the down button for 10 seconds. Now fully lift the glass and pull the button up and hold for 10 seconds.
It says something in the link below. There is illustrated expression. I think you apply it to glasses that don't work
omerb 2019-11-03 20:21:50
08.05.2020 21:21 # 5
erhan78
Yes I tried all of these. I did not get a result. He writes in the booklet that he protects and locks the buttons. As it happened to me, it says that it locks all but one button. But it says it opens after a certain time. But mine remained locked. There is no method I have not tried. I can say that I had trouble with my problem. € 557; € 557;
08.05.2020 21:21 # 6
pusutr
There is a thin plastic piece underneath the glass release buttons. Probably they were broken and displaced. I hope they haven't fallen down. If you place those parts neatly and carefully insert the buttons, the problem will be fixed.
08.05.2020 21:21 # 7
omerb
It seems like you have a physical problem rather than a software.
There are a few videos on the peugeot window switch repair summer google. Watch it. Maybe you notice something missing.
08.05.2020 21:21 # 8
erhan78
I did what you said. I removed it completely because it was probably because of it, but I carefully placed it, but the result is disappointment. Thank you so much
08.05.2020 21:21 # 9
erhan78
Thank you. Let me investigate it like that.
