Emergency aid gas pedal failure
08.05.2020 19:49 # 1
ARDADOGAN
P 1645 malfunction in the vehicle gives the accelerator pedal malfunction.
08.05.2020 19:49 # 2
would you check the socket on the accelerator pedal there. remove and clean
08.05.2020 19:49 # 3
ARDADOGAN
The brain ripper has not been cleaned, no malfunction is not erased, but it has no effect on the car. The PC does not light up the malfunction lamp, it does not leave it on the road, the master said. Now the only problem we have is that the problem appears when the pc is connected, but everything is normal in the car ...
[QUOTE = sonerkyl] can you check the socket on the accelerator pedal there. remove and clean [/ QUOTE]
08.05.2020 19:49 # 4
Then there is a short circuit somewhere, my teacher will not have another reason.
08.05.2020 19:49 # 5
ARDADOGAN
The brake crank was defective and the replacement was broken, but the strange brake crank is causing the accelerator pedal failure.
08.05.2020 19:49 # 6
Yusuf73
Peugeot 307 sw 2006 I have the same problem P 1644 plus short circuit code error is not deleted We tried the accelerator pedal was not deleted I would be glad if you help
27.01.2021 15:49 # 7
ARDADOGAN
Do you have a cruise control?
