Emergency Aid Gas Disruption
08.05.2020 20:18 # 1
playhard52
SelamınAleykum brothers and sisters
My Vehicle 2003 Model 206 1.4HDI XR Model Km: 203,000
I have Idle Imbalance in my vehicle. The engine is running too shakyly while idling and the tachometer is constantly playing.
In addition to this, the vehicle suddenly cuts off the gas while driving on the road. The accelerator pedal goes for 2-3 seconds. He's Starting To Do This Too Much Now. I am writing down the error codes we receive when we connect to the computer.
The Air Flowmeter of the vehicle has been replaced with the original one.
1- P0704 Clutch Switch Input Circuit Malfunction (Changed)
2- P1628 Accelerator Pedal Sensor / Brake Lamp Switch, False Signal
3- P0571 Cruise Control / Brake Switch A Circuit Malfunction
P0113 Intake Air Temperature Sensor Circuit, Short to Plus or Open Circuit
5- Mass or Volume Air Flow Circuit Low Input.
Thank you for your help in advance.
08.05.2020 20:18 # 2
Hello, welcome to us first. Have your car's engine ever been washed? Let me ask you this, although it gives you 3-4 fault codes, the vehicle knows for a simple reason. have your fuses and box checked first. First of all, change the place where you get your fuel.
1-Replace the brake sensor.
Replace 2-crank speed sensor
3-Replace fuel filter (definitely needs to be original.)
4-air filter (original definitely)
08.05.2020 20:18 # 3
playhard52
[QUOTE = sonerkyl] hello, welcome to us firstly. Have your car's engine ever been washed? Let me ask you this, although it gives you 3-4 fault codes, the vehicle knows for a simple reason. have your fuses and box checked first. First of all, change the place where you get your fuel.
Thank you very much for your answers. I changed the brake sensor. I don't think there is a problem with the crank speed sensor because we've looked at it before. Air Filter Original Replaced. I Changed The Fuel Filter, But If I Don't Remember Wrong, The Sub-Industry Was Installed. Actually, I Do Suspect Of The Fuel Filter Because The Ripple Problem Has Begun To Be 1-2 Week After The Change.
08.05.2020 20:18 # 4
As I said at that time, I would recommend that you replace the filter with the original one and buy the fuel from a different station. even fuel can cause such problems, but sub-industry filters are the very first reasons
08.05.2020 20:18 # 5
KILIC
I was skeptical of the gas sensor. give it a try
08.05.2020 20:18 # 6
lazerburak
First of all, I think your problem is completely potentiometer 100 TL.
08.05.2020 20:18 # 7
playhard52
[QUOTE = lazerbrak]] first of all, your problem is I think the potentiometer 100 tl change part will be corrected. If you go to a competent master, you can solve it quickly.
Is the gas pedal sensor you call potentiometer playhard52 2017-04-11 00:04:55
08.05.2020 20:18 # 8
lazerburak
yes accelerator pedal sensor
08.05.2020 20:18 # 9
sdttn
Regardless of the brain sockets, it is not normal for it to fail so much.
Alter the alternator just in case your test is done.
Go to a good electrician, or even a place that does brain work.
