Emergency aid for oil leaking through oil filter seal
08.05.2020 19:50 # 1
Deniz44
08.05.2020 19:50 # 2
Whoever put it on during the last oil change, it is a plastic material originating from it, it has survived the teeth - it has cracked because it has been over-tightened, or it has been leaking because it has not changed its gasket or it could not fit completely.
08.05.2020 19:50 # 3
Deniz44
My brother, I put on a zero cover, I put it on the gasket yesterday, I reset the hwps again, but we have a job if it will make a bole every 9 thousand
08.05.2020 19:50 # 4
[QUOTE]
The same master, change the staff, not the master, I did not have any problems, always remind the master to pay attention to the master.
08.05.2020 19:50 # 5
Deniz44
They make this gasket very stiff, I always have a problem there. Is there a solution for this? I put the water gasket on it.
08.05.2020 19:50 # 6
oguzhan29
You have changed the cover, but did you have it checked in place, your friend throws the filter and eats the engine because it is bad in the symbol vehicle. there is no reason that these situations would not be taken lightly
