EMERGENCY AID. FAULT LIGHT.
08.05.2020 19:14 # 1
TugyyStyle
Engine auto diagnostic indicator lamp is on when the ignition is on. What is wrong?
With the ignition on;
While the vehicle is running;
08.05.2020 19:14 # 2
berk2309
Do not be excited by my teacher, half-contact in every car, because the test stage will not start without the engine running, ignition for the engine, spraying, burning, etc. cannot be calculated :)
08.05.2020 19:14 # 3
TugyyStyle
Hodja, we are younger, our first car needs help :)
Well, if we start the starter before that light goes out, it would be a problem :)
08.05.2020 19:14 # 4
berk2309
Whatever you do, my teacher will not end without pressing that light marsa.
08.05.2020 19:14 # 5
berk2309
In other words, if the engine test does not start, when the light comes on, there is no problem in the engine of the vehicle, soner is straight :) The cerebellum box called BSI does not measure. berk2309 2015-04-27 22:53:29
08.05.2020 19:14 # 6
TugyyStyle
May my Lord grant us a happy life, teacher :) Thank you for your interest :)
08.05.2020 19:14 # 7
TugyyStyle
If you say no problem, no problem, teacher :))
08.05.2020 19:14 # 8
pusutr
:D
08.05.2020 19:14 # 9
themurat54
No no problem no problem :) even if you change the air filter of the vehicle or do something about the air filter, keep in mind that the malfunction light will come on. Don't think there is a malfunction later on. How many times has it happened to me? Let me know that you are new like me, so I'm telling you soon change oil care filters or something: D
