Emergency aid engine noise 206 1.4 hdi
08.05.2020 20:54 # 1
bozajuniors
Hello everyone, this is how I started idling in a moment when the vehicle was working normally. There is also a rattling sound when you press the gas. There is no problem in oil and water. When operating the vehicle on the display just two days ago the oil Max. - Min. There was a decrease in the screen, then returned to normal. In this way, it would be a problem to go to the mechanic.
08.05.2020 20:54 # 2
I did not listen to the teacher voice but youtube is closed in the company :) this sound event can cause a few parts valves - injectors - pulley and bearings. If you have an attractive service that I do not suggest you take too much risk, you can take it to the free industry in your fuse.
08.05.2020 20:54 # 3
onlycihan
The external pulley of the engine, which rotates accordingly, is similar to the sound of the belt, etc. The sound of the engine is clean but it looks like the sound of an external rotating auxiliary element.
08.05.2020 20:54 # 4
Adem Kurtuldu
Is there a problem with oil burning jerky work etc.
08.05.2020 20:54 # 5
bozajuniors
Thank you for your messages. the sound of the vehicle making the crankshaft pulley.
08.05.2020 20:54 # 6
onlycihan
Handshake
08.05.2020 20:54 # 7
ersin61
The crankshaft pulley can be ...
