Emergency aid
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 21:26 # 1
akgl3453
Hello friends, I have a Peugeot 301 2013 model car. 121 thousand. 1.6 hdi
I have a problem in the vehicle. For example, I am driving at a speed of 80 km. It does the same problem at the speed-as-fast setting. The vehicle is set 70 km down, no matter how much gas I give, it does not pass 70 or passes to the flow. Where might it originate from?
akgl3453 2020-01-13 22:41:34
08.05.2020 21:26 # 2
omerb
Hello. Did you just buy the vehicle? Have there been these problems before.
08.05.2020 21:26 # 3
akgl3453
When I just bought the vehicle, I noticed that I had 301 before and I did not have such a problem with him.
08.05.2020 21:26 # 4
omerb
The vehicle becomes slightly unbalanced when dpf is activated. The event you're talking about can happen at that moment. When it does so, the speed of the vehicle at idle is higher than normal. Dpf is enabled.
08.05.2020 21:26 # 5
In addition, use your vehicle at a high speed in a suitable place, such as a ring road, in low gear.
