EMERGENCY AID
08.05.2020 20:17 # 1
metuna84
ShockedShockedShockedShockedShocked I WANT EVERYONE, I HAVE A PEUGEOT VEHICLE WAS 207 DIESEL 2009 MODEL WHEN THE VEHICLE HAS INCREASED WHEN THE VEHICLE IS ALREADED, I WOULD LIKE ABART EXHAUST, I WOULD LIKE TO TAKE I LIKE I LIKE I HAVE TO TAKE I LIKE TO TAKE I LIKE TO TAKE I LIKE ABOUT. aS EVEN MORE POWERFUL, STOP ET I let it run STILL tHE SAME while at FENA Galder exaggeration of noise, dEPARTURE dIFFICULT will depart SECOND GEAR STILL a LITTLE BETTER GEAR büyüdükce the TAP TAP THAN SOUND DECLINING BUT FULL does GEC, FULL STOP wHILE MUCH flickers Refer SHAKY oFFICIALLY, waiting for your comments your HELP THANK YOU URGENTLY NOW.
08.05.2020 20:17 # 2
teacher, it is forbidden to write in capital letters due to forum rules. When it comes to your problem, first connect to the computer and look at the error codes of my teacher. There may be many reasons for this.
1-injectors
2-diesel pump and its installation
3-turbo and egr valve etc.
4th floor
5-oxygen sensor
it is difficult to make a precise comment without looking at the error code.
08.05.2020 20:17 # 3
metuna84
Hello, I'm sorry, I did not pay attention to that rule, I will be more careful from now on, the problem has become clear.
08.05.2020 20:17 # 4
Oktkor
What did the downhill of the vehicle engine affect? I did not understand that part. Can the engine not swing?
08.05.2020 20:17 # 5
metuna84
There was a plug in the engine part of the vehicle before they changed it, the masters did not remove the connections of the engine in order to pull the motor one, and probably did not tighten the screws well or put it in balance when the engine was back after the work was done. The motor is broken down or broken down, and at the end of this, the gearbox motor connection is broken, the vehicle was not gone, so the friends did not go, so if you are doing your job in the industry, we have to wait in the press no matter how much we trust you, we normally do the job of 100 TL, and unfortunately they do a job of 100 TL.
08.05.2020 20:17 # 6
Unfortunately, the careless masters who rush the job in the past are very unfortunately, in fact, the master must cover the cost, but where are the masters of the engine, the ear of the engine does not turn out to be a bigger expense.
