Emergency aid ---
08.05.2020 20:39 # 1
mehtur1510
friends had the same problem 3 months ago. I got in the car, I turned the starter, no clicks, everything works, headlights wipers, tape indicators, lights only when I turn the ignition, click, no sound, the same problem happened. I'm really confused, why do you think emergency help?
08.05.2020 20:39 # 2
My margin engine is out of order. My teacher is stuck. Move it back and forth a little in gear. Hit the margin engine. If the automaton is lit, there is nothing to do, you will have to take it with the tractor again.
08.05.2020 20:39 # 3
mehtur1510
I can't find my car automatic gear starter engine, where is it?
08.05.2020 20:39 # 4
Orcun.Dmr
My teacher had the same problem with me, even I had the same problem 1 year ago, then it was fixed. When I remove the starter and look at it, the coil inside it burst and jammed, and the starter got diesel inside the engine (because it misses the return hoses). I replaced the coals with orj valeo and bought an electrician friend in the coil and it blew me 80 tlye. Starter dynamo is behind the engine and very difficult to disassemble, they put the engine in trouble.
08.05.2020 20:39 # 5
RP393
[QUOTE = kskfurkan] Hello, my friends, I have 5008 vehicles. I was looking for a special service for winter maintenance and replacing my original products. .Erdem Usta took care of my vehicle and showed every piece that came out. All the filters he installed were original; Air filter, oil filter, pollen filter, fuel filter, pads were all original peugeot product ... You too, instead of getting a good service and changing a permanent repairman and you can get help from experienced masters. Phone number: 0232 376 76 04 [/ QUOTE]
If the parts to be changed are obvious, I always take it myself, master. I would like him to separate the resulting pieces. Not that I will sell it for scraps, but I want to see why it has changed and what has become. Unfortunately, people are afraid to do these things. However, we give the money we earn by working for hours. I passed it, we put our loved ones in that vehicle. I congratulate the service you mentioned. I suggest that everyone do the same as I said.
