EMERGENCY AID !
08.05.2020 18:31 # 1
cakirbey35
Good morning everyone good friday ..
As you know, I have a vehicle of 206 xs 1.6 110.It is at the original height of the vehicle, it has 195 * 55 * R15 tire size. I would be glad because I want to finish this process next week, thank you very much everyone in advance.
08.05.2020 18:31 # 2
Burak
If you wear 5cm, I know that it will drop 5cm. There are many 206 members belonging to our members in the 206 section of member vehicles.
08.05.2020 18:31 # 3
yawruaslan
A 5 cm spring 206 xs http://img203.imageshack.us/img203/2630/1wn2.jpg
08.05.2020 18:31 # 4
cakirbey35
[QUOTE = Burak] If you put 5cm, I know that it will drop 5 cm. There are 206 members belonging to our members in the 206 section of member vehicles.
Well, can we lower the back torsions as much as we want or do they decrease a certain size?
08.05.2020 18:31 # 5
cakirbey35
[QUOTE = yawruaslan] 206 xs with a 5 cm spring http://img203.imageshack.us/img203/2630/1wn2.jpgukuki/QUOTE]
+1
08.05.2020 18:31 # 6
Burak
I know that it is falling as a tooth
08.05.2020 18:31 # 7
cakirbey35
[QUOTE = Burak] I know it is falling as a tooth. I heard about those who said I dropped a tooth and two teeth [/ QUOTE]
I think 5cm eibach to the front if I wear a distance between the tire and the fender or something.
08.05.2020 18:31 # 8
Burak
[QUOTE = cakirbey35] [QUOTE = Burak] I know that it is falling as a tooth.
something like that happens around
08.05.2020 18:31 # 9
cakirbey35
[QUOTE = Burak] [QUOTE = cakirbey35] [QUOTE = Burak] I know that it is falling as a tooth.
thank you i think i will print some more if my decision is not clear after installing it :)
08.05.2020 18:31 # 10
Burak
[QUOTE = cakirbey35] [QUOTE = Burak] [QUOTE = cakirbey35] [QUOTE = Burak] I know that it is falling as a tooth.
I look forward to the result :)
08.05.2020 18:31 # 11
cakirbey35
[QUOTE = Burak] [QUOTE = cakirbey35] [QUOTE = Burak] [QUOTE = cakirbey35] [QUOTE = Burak] I know that it is falling as a tooth.
Of course, I will definitely publish the photos within 2 weeks. I will be able to handle it, window film, sports bow and rc spoiler.
08.05.2020 18:31 # 12
emre_akdag
I am not very idea about this, but if you are undecided, I think I will wear a 3.5 cm bow first. Drop 1 tooth from the rear torsion. If it does not satisfy you replace it with 5s. Of course, this is my idea, I even think of doing it like this: D
08.05.2020 18:31 # 13
cakirbey35
[QUOTE = eksper_emre16] I am not very clever about this, but if you are undecided, I think I will use a 3.5 cm spring. Drop 1 tooth from the rear torsion. If it does not satisfy you replace it with 5s. Of course, this is my idea, I even think of doing it like this: D [/ QUOTE]
I will see my 5 cm will be enough, 3.5 will see my work, I know it :) I can even wear 7cm if my settings escape LOL
08.05.2020 18:31 # 14
kuscu38
http://www.peugeotturkey.com/nasil_yapilir.asp?makaleıd=95
here is related to sound removal but the distance between the chassis and the gap in the first picture is important. Whether ... You can do the opening of the fender mouths to the greasy draw without taking too long time.
08.05.2020 18:31 # 15
cakirbey35
[QUOTE = kuscu38] http://www.peugeotturkey.com/nasil_yapilir.asp?makaleıd=95
If I wear a 5cm sports bow, would it rub in the rubber bonnet? as I have stated, the original rim and tire sizes are available in my vehicle Confused
08.05.2020 18:31 # 16
kuscu38
As the last vehicle is pressed, the tire goes up the fender, that is, and the fender becomes narrower inside, my teacher, I said to keep it in mind. And also I did not say for the sports spring wearer, I said if the rear torsions are dropped excessively, but I did not come across this forum for those who had trouble when they dropped 5 cm and equalized both sides :)
08.05.2020 18:31 # 17
cakirbey35
[QUOTE = kuscu38] As the tire is pressed, the vehicle goes up from the fender, that is, and the fender becomes narrower inside. and also for the sports spring wearer, I said if the rear torsions are dropped excessively, but I did not come across this forum for those who had trouble when they dropped 5 cm and equalized both sides:) [/ QUOTE]
no I won't drop it too low, the back will be flush with the front
