Emergency aid 2004 1.6 xr lpg
08.05.2020 19:51 # 1
Mehmettr22
I am thinking of buying 307 friends I will be gasoline and LPG.
08.05.2020 19:51 # 2
[QUOTE = Mehmettr22] I'm thinking of getting friends 307 gasoline and lpg lia my head birqz mixed lpg bsi I've heard that it is hurting your brain user waiting for the help of friends thank you now [/ QUOTE]
it has nothing to do with my teacher, it is a situation caused by wrong assembly. good master good assembly no problem.
08.05.2020 19:51 # 3
Mehmettr22
Thank you, my friend. So what kind of problems will this be my first 307?
08.05.2020 19:51 # 4
My brother Mehmet first look at the engine water of the vehicle, antifreeze used car is the priority, then you will have a lot of trouble with the engine. In other words, if the second hand is a bit of luck, when you look at the vehicle, if you sneak into it, if it is worn out, it is a problem. undercarriage problems usually take the lead, definitely check the engine condition in the composite. If it is below 85-90%, check undercarriage pressure pad and undercarriage. discs stopped etc. glass automatic control whether all doors are opened, control the lights, check all the lights. This type of details are often overlooked. Look at the airbag lamp. If the vehicle does not go out while running, 500 TL cost of headlight-wiper arm needs to be changed. When was the last time the timing was changed? I hope it will be good.
08.05.2020 19:51 # 5
KILIC
If the vehicle you will buy is a maintenance-free vehicle, you can be confused with any problem. If the car you buy is a well-maintained car, you may encounter any problem.
08.05.2020 19:51 # 6
Mehmettr22
I thank you very much for the information you provided. As a result, it is a must to find a clean one.
08.05.2020 19:51 # 7
As our teacher friend said, there is no guarantee of any second hand. Every vehicle can break down, whether it be bmv or mercedes, it depends on the user if you find it clean. I got the focus in meganda astra, I dealt with a lot of problems in all of them.
08.05.2020 19:51 # 8
KILIC
It is an equipped vehicle according to the price of 307. If you find the cleaner, it is inedible. But there is a fact that if you buy the cleanest and most well-kept car, you will not know what will happen tomorrow. Burning an ecu is instantaneous, you can't even understand it's the most. For this reason, if it has gotten inside, take it without hesitation. There are people who buy even zero cars and have problems.
08.05.2020 19:51 # 9
lamazibici06
I have 307 xt. Thank goodness lpgli never had any trouble.
08.05.2020 19:51 # 10
samet206
I agree with other comments. Everyone has a different chance of second-hand luck. When looking at the car, if it catches you, if there is anything to say, there is nothing to say other than that. What to look for when buying the remaining classic car is the same for all.
