emergency aid!!
08.05.2020 17:58 # 1
mrtoknctn
friends hello;
The problem came to me yesterday, I started the road between Ankara and Karabük, when I arrived, the car was cutting off the gas at a low speed, it became worse after a while, but when I pressed the gas, the car was recovering, while the vehicle was running at idle, the vehicle is stabbing, but the steering is still suspect from the soft idler reader .. My vehicle lovato branded system I would appreciate if you can help with LPG and manual gear
08.05.2020 17:58 # 2
Observe the situation while on gas. If there is the same situation there, the throat butterfly will be the first place to see it.
08.05.2020 17:58 # 3
engin6162
My brother had the same problem in my car, the gas butterfly throat was stashing because his throat was full.
08.05.2020 17:58 # 4
serkans
I had the same problem with spark plug replacement, all of them were halo for 100 lira
08.05.2020 17:58 # 5
serkans
with butterfly cleaning and calibration
