Emergency aid
08.05.2020 21:12 # 1
Sabridemir
Q. A friend of mine, I would ask you for help, my car is all over, so it always falls and disappears, usually it does when the car is cold, it returns to normal after 10 minutes. Do you have anybody or anybody know?
08.05.2020 21:12 # 2
First of all, welcome to us. Okay, teacher, the charger has been controlled in the vehicle. there may be a voltage problem. engine ecu needs to be checked as well. voltage values should be checked when the engine is cold.
08.05.2020 21:12 # 3
Sabridemir
Thank you. Nobody did not detect until the water was not connected to the machine. This is where they handled it. No, yes, the current is not provided. The guy said he was always cold. He did not do this. they said it is possible, they said it was right, I said zero right, I dont have zero battery again thank you for helping
08.05.2020 21:12 # 4
Orcun.Dmr
Original software Peugeot Planet 2000 computer with voltage values and if necessary, it is necessary to look at the fault record, teacher. Detection without a computer is not very accurate.
08.05.2020 21:12 # 5
Sabridemir
Well, I have to go to my electronics shop. In this case, I went to the electronics shop, I went to the machine, it was not connected to the machine.
08.05.2020 21:12 # 6
KvncKR
alternator (charger)? I don't think it would be easily from the brain, I would say if it were 307
08.05.2020 21:12 # 7
Sabridemir
Your friend did not look at anyone, I visited 5 shops, all of them were naughty, I did not understand me.
08.05.2020 21:12 # 8
Sabridemir
Problem konjektormus friends I wanted to inform about 18v when the vehicle was cold thanks
