Emergency aid
08.05.2020 21:00 # 1
adnankaraevli
selamınaleykum pejo 206, while the vehicle is waiting in the red light, the temperature rises to 120. The fan is turning on at 120. When the vehicle moves, I drove back to 90. I took the vehicle to the master. ?
When the bidet pushes the car, there is a lot of white smoke in the back. What should I do?
08.05.2020 21:00 # 2
GokhaN
120 too high value is ok, etc. there is no problem there may be a problem in the indicator. your vehicle is diesel?
08.05.2020 21:00 # 3
adnankaraevli
no gasoline
08.05.2020 21:00 # 4
Lokman35
I have a similar problem too. When my cycle is high and it is going on the ramp, the fan doesn't even turn on where it stops.
08.05.2020 21:00 # 5
adnankaraevli
thanks
08.05.2020 21:00 # 6
Selcuk55
White smoke indicates that the water is going to different places. The gasket may be burned. If the gasket is burned, you can not save from heat anyway.
08.05.2020 21:00 # 7
Lokman35
when my vehicle speed exceeds 130 and goes over 90 c on the ramp but did not exceed 110 u is this normal?
08.05.2020 21:00 # 8
[QUOTE = Lokman35] when my vehicle speed exceeds 130 and ramps over 90 c on the ramp, but not exceed 110 u is this normal [/ QUOTE]
It was 206, my teacher, I did not have a problem. but never use the vehicle without antifreeze.
08.05.2020 21:00 # 9
Lokman35
[QUOTE = sonerkyl] [QUOTE = Lokman35] when my vehicle speed exceeds 130 and ramps over 90 c on the ramp, but did not exceed 110 u is this normal [/ QUOTE]
Ok thank you
08.05.2020 21:00 # 10
27BEN80
IF THE FAN IS LIVING, THERE IS A DIFFERENCE, REVOLUTION, LOOKING TO OWNERS AND COPYERS, IF THE MOVEMENT IS HIGHLY CONTINUOUS, IT MAY HAVE BURNED ON THE JACKET JAPAN.
