Emergency aid...!
08.05.2020 19:17 # 1
uslucihan
Hi aleyküm friends, easy come 2004 1.4 petrol lpg li 206 have on the way stop text and oil indicator light flashes instantly, we changed the oil filter oil pump, but it has not improved yet it may cause another
08.05.2020 19:17 # 2
To get past, my teacher connected to the computer which error code is the vehicle giving. The error code should be checked first, it may have caused another reason, perhaps it may be a problem with lpg. It turns out that I will throw the stop gear in neutral, or is it in gear. my gas pressure will burn my anxiety from the gas, it will burn, and will try to help if you specify these exactly. Experienced friends in the forum.
08.05.2020 19:17 # 3
uslucihan
When we were driving, I had a problem with the oil when I couldn't connect it to the computer.
08.05.2020 19:17 # 4
Cyrus35
Let me tell you what happened to me. You check it just in case.
I added oil to the brake hydraulic box. Nevertheless, it should not be said that it is good, for mechanical tools. Check that each oil box and water box are greasing at its own level.
08.05.2020 19:17 # 5
uslucihan
I have to look, I hope so
