Emergency Aid 106 xr
08.05.2020 18:33 # 1
omervolkan
First of all my selamun aleyküm vehicle 106 xr complaint when I gave full throttle in 1st gear, I went to the mechanic, went to the mechanic, they said, I changed the gas pump and when I reached the 2nd gear 100 km / h, I cut the gas continuously and got it back to the same computer as it would recover 1-2 seconds later. carbon filter solenoid valve malfunction I have no chance to try it because the part is expensive and it is not where I live.
08.05.2020 18:33 # 2
Serkan
Is 2nd gear 100 km / speed?
08.05.2020 18:33 # 3
superyusuf
What is the 2nd gear and 100 km girl doing?
I have 106 xr too ... I am tickling that fast on the 4th gear but ....
If it is said so, you will do it and look at another master, let's see.
superyusuf 2014-05-21 09:56:32
08.05.2020 18:33 # 4
omervolkan
While trying to drown, the pressure bar is between 80-100, is it revived and drowned?
08.05.2020 18:33 # 5
Serkan
I think you don't need to do anything if it does it only when it reaches 100 km / h in 2nd gear.
08.05.2020 18:33 # 6
omervolkan
In 2nd gear, I do not come to the circuit breaker, I throw 3 to 5 km speed, but the car could not be understood as if gasoline would come and go.
