|   | Emergency aid. 1 tl is burning in gasoline. 106 xr |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 18:42 | # 1 |
|  sertac.ulas | |
| 08.05.2020 18:42 | # 2 |
|  suppor | |
If you are using the city constantly and you are using the series, it is still more than 60 70 patterns, 100 kurus a bit more in my normal skin :)  In addition, if the injector is blocked, go get the würth for injector cleaner, I have 206 hdi, I used the diesel one, the performance is improved, the draft has improved, the sound has decreased, what more can you get :) I bought it from shelld, I will buy it from 300ml there, or 30 or 50 liters of gasoline until the top speed is over. Try it, I'm glad. | |
| 08.05.2020 18:42 | # 3 |
|  sertac.ulas | |
If I get lpg, will this problem be solved? What will lpg burn?
| 08.05.2020 18:42 | # 4 |
|  outlaw | |
NORMALLY IT WOULD NOT BURN IT. IT IS VERY SATISFIED.   REASON FOR OVER BURNING;   * SPARK PLUGS MAY   * THROUGH BUTTERFLY   * MAY BE OXYGEN SENSOR   * VALVE ADJUSTMENT ADJUSTMENT   My brother is burning 25 krs in LPG.   STOP THE REMOTE FROM THE MASTER WHO LIKES TO REMOVE THE INJECTOR PROBLEM WHEN LPG IS CLOSED.  | |
| 08.05.2020 18:42 | # 5 |
|  sertac.ulas | |
Doesn't the problem disappear when there is no need for a petrol puskurten injector?
| 08.05.2020 18:42 | # 6 |
|  sezar206 | |
Install the lpg first, if the problem is not resolved then you will look at this situation. But there are simple things you can do. Clean the throat butterfly, have the oxygen sensor checked. It is likely that the spark plugs are disassembled. Take it to a good pejo master, he already lists the possibilities for you. As for the subject of the injector, just as the suppor says, there is a würth on half tank gasoline, take a box, put it into the tank, try it at every cycle until the gas light comes on. In fact, first of all, make the butterfly spark plug and würth rank and change it if the petrol filter is old.
| 08.05.2020 18:42 | # 7 |
|  sertac.ulas | |
Thank you 2 I will try all the possibilities within 3 days, hopefully the problem will be fixed.
| 08.05.2020 18:42 | # 8 |
|  06fatih66 | |
I have 97 106 xr 2 years ago, I got atiger line system, I traveled 560 km, burned 90.00 TL, of course, I made a fixed 90 km speed, and in the city, it will burn 20.00 TL in 100 km.
| 08.05.2020 18:42 | # 9 |
|  06fatih66 | |
It came to my mind that if the injector is blocked, the piston that is clogged does not spray gasoline and the car will burst and fall off. Do not forget that if the idling sensor is faulty, the vehicle will run at high speed, the spark plug will not burn in the cylinder chamber on the ignition side that is similarly defective in the spark plug cable and the coil, but if it conducts, equal power is obtained. Since the vehicle is not pulled, the vehicle will not be good and the vehicle will be pressurized to the gas, you will have a bakite or exhaust examination to the oxygen sensor. if you work with the left, it is oxygen sensor if it works smoothly and it works very smoothly.
| 08.05.2020 18:42 | # 10 |
|  sertac.ulas | |
Raw fuel comes from the exhaust. I feel it when I hold my hand. It smells like petrol in my hand. As you say in the slopes, he wants to use gear constantly. It seems like a very rare vague misfire in the morning. And sometimes it makes it so rare that the engine shakes the vehicle while it is stationary.  | |
| 08.05.2020 18:42 | # 11 |
|  06fatih66 | |
It is necessary to see the vehicle because there may be many reasons for that shock, if there is an avalanche fuel in that oxygen sensor, there may be a problem of not firing properly in one of the cylinders. and when you test it, the person who understands can tell us that the breakdown is here without stumbling and can not distinguish anywhere.
| 08.05.2020 18:42 | # 12 |
|  06fatih66 | |
but the first thing that comes to my mind is that one of the exhaust valves that might be faulty is missing and the setting of the valves is tight, the second may be the oxygen sensor.
| 08.05.2020 18:42 | # 13 |
|  sertac.ulas | |
Can you write your phone number? I'll tell you from there.
| 08.05.2020 18:42 | # 14 |
|  Berke106 | |
I] There are 99 Model 106 XR, scuba and burn 23-25 cents per km. As friends say, cleaning etc. If you do, it will not drop as low as the LPG burning.
| 08.05.2020 18:42 | # 15 |
|  sertac.ulas | |
I already have LPG but the important thing is that when I wear LPG, it won't burn much
| 08.05.2020 18:42 | # 16 |
|  Celik36 | |
What does this mean 1 TL to your brother?
| 08.05.2020 18:42 | # 17 |
|  sertac.ulas | |
We are trying to solve the problem anyway.
| 08.05.2020 18:42 | # 18 |
|  peugeot murat | |
Set valve to the vehicle, change the spark plugs, check that the water temperature and air temperature values are correct.
| 08.05.2020 18:42 | # 19 |
|  Ali1905 | |
My teacher was idling in my car;   Petrol injection spraying time = 4.2 ms   Map pressure = 400 millibars   I do not know the temperature of the entrance air, but I remember that the room is high,   This gasoline injection spraying time had to be between 2.8 and 3.2 at idle. I couldn't figure out what I did.   Since the spraying time is high, the vehicle is a bit too heavy.  | |
| 08.05.2020 18:42 | # 20 |
|  peugeot murat | |
Valve adjustment is made, the injection continues
