emergency 407 2.0 hdi turbo sound
08.05.2020 15:12 # 1
falcon_78
We have 407 2.0 diesel vehicles and since the car we have started to hear more noise from the turbo recently, around 77.000 km, I wanted to get information from you before I went to the service. I couldn't hear that sound because of the voices
08.05.2020 15:12 # 2
possibly the turbo shaft has begun to be worn. Generally, this sound starts to be caused by transcendence. some vehicles may be experienced early. your turbo will either be maintained or changed completely ...
08.05.2020 15:12 # 3
falcon_78
how much will this cost
there is no sourn at the vehicle's traction and going
Despite being used so carefully, the emergence of problems in this style is very annoying
all maintenance is carried out in the series
and the operations done in the service do not satisfy me very much, last year the steering has hardened and it started to turn hard. 1 year has passed since the oil will still decrease and the steering pump will change and they asked me 1200 TL for this pump.
In addition, when I went to the routine maintenance service, they put normal diesel oil on the 2.0 diesel engine.
The reason why I have a few problems that come to me in this way is that I want to find a solution to my possible problem without going to the services, otherwise it will be said that it will change and then it scares me that the part will be intact, so I don't want my vehicle to be handled in vain.
08.05.2020 15:12 # 4
The importance of the competent master (not the service) is now the languages in the forum. It is normal that you did not notice it as you are new.
My advice to you is to shoot a video of the sound and put it here. Then the point-shot suggestions will come. There are a lot of turbo issues and almost all the sound difference.
08.05.2020 15:12 # 5
falcon_78
I will try to add your video soon
08.05.2020 15:12 # 6
Very nice. If you have other photos, you can share them by opening a new title in UYE TOOLS. Hullo.
08.05.2020 15:12 # 7
mimitt
Sorry, the turkey population as we have a very incomplete information about turbo diesel, in my previous tool to incorrect oil put the result of the turbo broke down completely, turbo systems, rules need to be considered in the engine start and stop with the ignorance of var.servis this situation thoroughly triggered.
Closed box in turbos, there may be more than one reason for the sound.
08.05.2020 15:12 # 8
falcon_78
As you said yes, turbu vehicles are systems that require attention.
Every time I started, I paid attention to the waiting times required for the turbo to not cause problems in the future for a certain period of time before the lights go out and move and stop, but we can no longer do anything more than say arabic.
other than this vehicle, I have corsa diesel vehicle, I did not have such problems but it does not mean that it will not.
anyway i hope i can't say anything other than saying there is no big sourn
08.05.2020 15:12 # 9
just307
I have researched this issue a lot, as I said it sounds like a whistling sound from the turbo, I think it was heard in the 1st and 2nd gears, but I think it was not heard in the high gears due to other sounds, I asked the turbo of my car 1 week ago, I asked 2 different authorized services first, the turbo should be changed in two services. I can't do the turbo repair, it can't do it, they said there were 3 different turbo in the new turbo except 1500 and 2500 TL workmanship. Of course, I did not get it done in the service. I got it checked and learned that the turbocharger and repair kit etc were worn, they should change, when I asked the cost, they said 500 TL, we agreed to 450 TL. I went to the turbocharger, I gave the turbocharger 450 plus special service 70 TL turbo disassembly, plus they did it in a few minor operations, it gave me the original 57 thousand km in my car. .
08.05.2020 15:12 # 10
ADM
ewt I have the same problem, they said the same thing in 2006 307 1.6 HDi 73.000 they made the turbo 600 repair 350 price 350 bargain 400 I changed it completely ..
08.05.2020 15:12 # 11
falcon_78
[QUOTE = just307]
where did you get this procedure I wonder if i live in zonguldak but i have the possibility to go to istanbul 2 weeks later i would be glad if you give information about the address but it is still useful to go to the service and make a pulse check
08.05.2020 15:12 # 12
59ice307
slm I have the same problem in me, I even pulled out the video and put it on the site, but if you give me the address, I can show my turbocharger .. thanks
08.05.2020 15:12 # 13
falcon_78
[QUOTE = 59ıce307] slm I have the same problem in me, I even pulled out the video and put it on the site, but if you give me an idea, I can show my turbocharger .. thank you
Do you have a link for the video you put on the site ??
08.05.2020 15:12 # 14
BAHTIYAR
http://forum.peugeotturkey.com/forum_posts.asp?tıd=13561&kw=&pıd=196953&title=turbo-sesi#196953
It has a sporty sound like blow of :)
08.05.2020 15:12 # 15
just307
I've made the sturgeon is not in istanbul these operations, Bingöl task I showed when I went to leave for my offender, turbo tırmas industry somewhere on the site, and now I do not remember the exact name but industry turbocan They show direct you've got a great place to have centers branches in myrtle in pistachio turkey guess the FIR working on the largest turbo they already had hundreds of turbo on the shelves, so they seemed good to me in this job, I trust me, I still have no problem at the moment. I think you can get it done
