|   | EMERGENCY 206 RADIO ASSISTANCE .. !!!! |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 13:58 | # 1 |
|  Guests | |
| 08.05.2020 13:58 | # 2 |
|  Guests | |
Suddenly the alarm text appeared and it was not opened even though you entered the code number ...   I will ask our service and get information for you, but something very strange: S  | |
| 08.05.2020 13:58 | # 3 |
|  sinan-s | |
An interesting problem. I suppose the tape broke down completely.
| 08.05.2020 13:58 | # 4 |
|  hasimayaz | |
How many models is the vehicle? I have not seen such a problem in RB3 and RD3 units since 2004. There is no code event at all. In 2004, eprom update may be required. Tape repairers make 15 - 20 YTL.  | |
| 08.05.2020 13:58 | # 5 |
|  Guests | |
car 99 model I do not understand sound and no problem opening and closing   but the frequency does not change. none of the other buttons press  | |
| 08.05.2020 13:58 | # 6 |
|  Guests | |
Waiting for your help, friends ....
| 08.05.2020 13:58 | # 7 |
|  hasimayaz | |
| Unfortunately, if you enter the code, but the problem does not improve, unfortunately you will need to take the tape to a tape repairer. The unit in your vehicle works completely independently from the vehicle brain, so it is impossible to have a fault other than tape. As if the eprom needs to be removed from the tape and reprogrammed in the eprom programmer. Of course, there will be a new code with the new eprom ..  If you were in Ankara, I could give an address, but I do not know anyone in Istanbul who can do this.  | |
| 08.05.2020 13:58 | # 8 |
|  entel | |
There may be a small space on the back panel of the tape to insert the needle tip (reset button), hold the toothpick or the pin with a toothpick or a pin for 5 seconds.  Then close the tape and open it. If the problem does not resolve, the eprom needs to be reinstalled, as Haşim BaBa says. | |
| 08.05.2020 13:58 | # 9 |
|  Guests | |
let me try and inform you
| 08.05.2020 13:58 | # 10 |
|  Guests | |
| I removed the tape, looked back, but I couldn't see a button like that  tape model 2040?  | |
| 08.05.2020 13:58 | # 11 |
|  Guests | |
| I mean, it has never happened to anyone before this event ... Thank you for your help .. | |
| 08.05.2020 13:58 | # 12 |
|  Guests | |
[QUOTE = hasimayaz]  Unfortunately, if you enter the code, but the problem does not improve, unfortunately you will need to take the tape to a tape repairer. The unit in your vehicle works completely independently from the vehicle brain, so it is impossible to have a fault other than tape. As if the eprom needs to be removed from the tape and reprogrammed in the eprom programmer. Of course, there will be a new code with the new eprom ..  If you were in Ankara, I could give an address, but I do not know anyone in Istanbul who can do this. [/ QUOTE] I think my brother follow a path in this regard ... | |
