Emblem on 206 keys
08.05.2020 20:56 # 1
hulya1558
The emblem on the key has fallen :( If I get the new one, the control automation will be broken? Is the simple PEJO EMBLEM sold one by one?
08.05.2020 20:56 # 2
automatic in the fabric does not deteriorate, just replace the outer plastic container. 20-30 TL can be solved in auto keymakers.
sonerkyl 2018-07-04 12:10:11
08.05.2020 20:56 # 3
luridline
Don't worry. Order one new control case from Aliekspres. You can find it in n11 too, but they don't give you down 20-25 pounds. Aliekspreste 1-1.5 dollars. Neatly remove the lion from the remote control without touching your own control. Clean up where your own controller comes out. (with a screwdriver) if there are signs of gluing beforehand. It is better if the Japanese have 502 or so, paste the new lion with epoxy.
When it wants to change the container directly, it may not be fully compatible. I bought it so that I could replace the old one. The circuit board inside did not fit. Later, two months later, the lion fell. I did as I said. It's simple and cheap. Don't ever deal with the keymaker
08.05.2020 20:56 # 4
luridline
Meanwhile, I saw that sonerkyl shared. You can make the system I bought. Sub-industry containers are not very good. When using the wrench, the screw may crack quickly from the joint. It already has a matte look. I suggest you just use the logo
08.05.2020 20:56 # 5
hulya1558
There is no logo on aliexpress screen, it is flat on the back and not on other sites
08.05.2020 20:56 # 6
hulya1558
https://tr.aliexpress.com/item/okeytech-for-peugeot-106-206-306-406-key-shell-2-button-ne73-blade-replacement-remote-control/32861062553.html?spm= a2g10.search0104.3.1.19141a29lwt9mw & ws_ab_test = searchweb0_0, searchweb201602_3_10152_10065_10151_10344_10068_10342_10343_10059_10340_10341_10696_100031_10084_10083_10103_524_10618_10624_10307_10623_10622_10621_10620, searchweb201603_31, ppcswitch_5 & algo_expid = 0963c5a9-a192-4754-80bc-2c17a2183e13-0 & algo_pvid = 0963c5a9-a192-4754-80bc-2c17a2183e13 & pricebeautifyab = 0
08.05.2020 20:56 # 7
hulya1558
ONDADA no emblem
08.05.2020 20:56 # 8
luridline
it usually comes without the emblem attached. It was when I bought aliekspressten. Let's check and return
08.05.2020 20:56 # 9
doganatak
I bought it from another vendor, I even asked the seller if there was no emblem.
08.05.2020 20:56 # 10
luridline
08.05.2020 20:56 # 11
hulya1558
Doesn't it take too long to arrive aliexpretn yes there is no photo emblem!
08.05.2020 20:56 # 12
hulya1558
Thank you, I did not find it.)
