ELM 327 Mini, OBD 2
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 20:13 # 1
Bahri
Hi friends, does anyone use the ELM 327 Mini, OBD 2 in peugeot301, read and delete the fault code. I want to get it from this device.
08.05.2020 20:13 # 2
ersin61
My friend has 206 hdi I have ELM 327 mini and I had a problem with connecting to the ECU. I had a friend from the same car and he worked on him. He was completely indexed with ECU compliance.
08.05.2020 20:13 # 3
206 2007 model gasoline, 407 2007 model diesel, no problem in the vehicles before 2004 There may be a problem in the models, as our friend says ersin61 does not support the room obd protocols in some versions, your vehicle will not be a problem.
08.05.2020 20:13 # 4
Bahri
[QUOTE = sonerkyl] 206 2007 model gasoline, 407 2007 model diesel, there was no problem in the vehicles before 2004 models may be a problem as ersin61 does not support the room obd protocols in some versions, as our friend says. I will share the result I will try here
08.05.2020 20:13 # 5
Bahri
[QUOTE = ersin61]
08.05.2020 20:13 # 6
I would like it. After 2004, these devices support all OBD protocols. there is no possibility of trouble, but if the device is faulty, you cannot take action. sonerkyl 2017-03-06 09:19:33
08.05.2020 20:13 # 7
ersin61
My car 2004 friend's vehicle 2004 is just the difference in hardware. Mine XT gave me the error of connecting to the ECU in my X-line and connected to the ECU directly in both of them.
08.05.2020 20:13 # 8
@ ersin61 teacher, these problems may be in the production before and after 6 months. Although ecu brands are the same, there are such connection problems due to differences in software versions.
08.05.2020 20:13 # 9
ersin61
It's true, man, as you said, a software difference
08.05.2020 20:13 # 10
erk4n
I was thinking to activate the road computer, but I did not have any other plans.
08.05.2020 20:13 # 11
Bahri
[QUOTE = Bahri] Hi friends, do you use the ELM 327 Mini, OBD 2 in peugeot301, read and delete the fault code. I want to get it from this device. Thank you in advance. Thank you in advance [/ QUOTE] friends today came to my hand tried ecu error it is not compatible. so it didn't work as a result
08.05.2020 20:13 # 12
@Bahri hocam 2011-2012 works in the 308s but I wondered how your 301 did not work.
08.05.2020 20:13 # 13
Bahri
[QUOTE = sonerkyl] @Bahri teacher 2011-2012 works in 308s but I was wondering how your 301 did not work. [/ QUOTE] my sonerkyl teacher contacted the seller, he wrote me that he used it incorrectly, he described it to me, I try again and write the result here. Also, the torque program software on cd is not old and turkish. https://yadi.sk/d/xmugd7t7s3wnx
08.05.2020 20:13 # 14
I understood my teacher, so youtube bmw is getting stuck in audi. thanks for adding the new and latest version.
08.05.2020 20:13 # 15
Bahri
[QUOTE = sonerkyl] I understood, my teacher, so youtube bmw audi is said to him. thank you for adding the new and latest version. [/ QUOTE] Grows as you share information
08.05.2020 20:13 # 16
Bahri
[QUOTE = sonerkyl] I understood, my teacher, so youtube bmw audi is said to him. Thank you for adding the new and latest version. [/ QUOTE] Hi, I set up the profile, let me explain the processes I did, but it did not happen. Select the vehicle from the profile, he wants me to write the vehicle information from there. I wrote them. I come to the face and open the settings of the adapter status, I enter the settings from the settings section. I open the OBD2 adapter settings and make the connection type bluetooth from the connection settings. I also choose obd2 from the bluetooth settings, but the connection is not made anyway. Bahri 2017-03-09 16:45:17
08.05.2020 20:13 # 17
CVT
I wonder if anyone using obd2 elm 327 device in Ankara?
08.05.2020 20:13 # 18
dejawu1978
friends today came to my hand tried ecu gave error not compatible. so it didn't work as a result
If you bought the Turkish version and the 2.1 version of the product you bought, I think the product you bought is the old version. Wink
08.05.2020 20:13 # 19
[QUOTE = CVT] Is anyone using Ankara from obd2 elm 327 device?
I use it. sanin 106 might not work.
08.05.2020 20:13 # 20
[QUOTE = Bahri] [QUOTE = sonerkyl] I understand, my teacher, I mean, they are beating youtube bmw audies. Thank you for adding the new and latest version. [/ QUOTE] Hi, I set up the profile, let me explain the processes I did, but it did not happen. Select the vehicle from the profile, he wants me to write the vehicle information from there. I wrote them. I come to the face and open the settings of the adapter status, I enter the settings from the settings section.
strangely still stuck in my mind. youtuba there are many videos that use in high model vehicles ie 308 - 407 - 206 - 307 - etc. I provided links to many models. I did not have any problems.
Page : / 2
