Electronic malfunctions
08.05.2020 14:05 # 1
emin_usta
Hi friends ..
Any electronic fault related to Peugeot (and other vehicles)
bsi + brain + chip tuning + immobilizer + performance measurement etc. whatever problem i am here Wink
08.05.2020 14:05 # 2
kitay
slm brother 206 xt 1.4 hdi 2004 model key mark in this vehicle, how can I fix it without going to the service tskler
08.05.2020 14:05 # 3
hasimayaz
[QUOTE = kitay] slm my brother 206 xt 1.4 hdi 2004 model key key in this vehicle, how to fix it without going to the service tskler [/ QUOTE]
Press and hold the button to the left of the instrument panel, without opening the ignition of your vehicle. While holding the button, turn on the ignition and after a while, a numerator will appear on the digital line, counting from 10 to 0. When it is 0, the service counter will run back from 20.000 km.
08.05.2020 14:05 # 4
[QUOTE = kitay] slm my brother 206 xt 1.4 hdi 2004 model key key in this vehicle, how can I fix it without going to the service tskler [/ QUOTE]
service maintenance came :)
I think that this process is getting better even though the ten console dashboard with half contact is pressed for about 10 seconds to knock there.
08.05.2020 14:05 # 5
fatih1903
So is there any harm in this process, guys?
08.05.2020 14:05 # 6
BurcUMUL
[QUOTE = fatih1903] well, is there any harm in this process, guys? [/ QUOTE]
When he goes to the service, he is doing the same.
08.05.2020 14:05 # 7
bsi water had entered the brain, they insulated the place where the water was entering the authorized service bsi wore their brains and reinstalled them, but on the same day it failed again. If we showed them, thank you for buying a new one.
08.05.2020 14:05 # 8
If you want to have a brain repairer who can handle these things, let me give a wire.
08.05.2020 14:05 # 9
Chıp software war is idling at 1100 in my vehicle. While the engine is warming up, the engine fluctuates between 800 and 1100 when it warms up.
08.05.2020 14:05 # 10
yasin_206
WHEN THE MOTOR IS COOLED, THE ALARM IS WRITTEN ON THE NOTIFICATION SCREEN. WHAT IS THE REASON OF THE REASON, HOW TO REMOVE THE PROBLEM AND THE SCREEN CHANGE OF THE EXAMPLE WHEN THE EXAMPLE IS SOUND, THE TRANSITIONS IN THE SCREEN ARE SLOWLY REALIZED SILIK IS RIGHT TO THE NORMAL WHEN THE MEDIA IS IN THE LIGHT DRESS ??? THANKS
206 ROLAND GARROS 1.6
08.05.2020 14:05 # 11
Sinan
My airbag lamp is on. can not find the error we put on the computer. why?
08.05.2020 14:05 # 12
zaferpls
My car's wiper works on its own, while parking and cruising
For now, I use the fuse by removing it, of course, in this case, I cannot use the lock, signals and sanroufuda in the center.
I will go and unplug the wiper cable as soon as possible, driving in this way is very risky, I can't even signal
08.05.2020 14:05 # 13
EminONAL
[QUOTE = hasimayaz] [QUOTE = kitay] slm my brother 206 xt 1.4 hdi 2004 model how to fix this tool without going to the service tskler [/ QUOTE]
I will try it soon. I wondered if it counts back from 20 thousand, does the key sign disappear?
08.05.2020 14:05 # 14
MY 2001 PARTNER'S KILOMETER TIME DOES NOT WORK CAN I TRAVEL THE PROBLEM IN THE KUYA
CAN YOU GIVE YOUR PHONE
THANK YOU REGARDS
08.05.2020 14:05 # 15
I have a 2004 peugeot partner, I closed the contact yesterday, the tape was closed, but when the map turned off, the lamp and the hill started to hurt, the door turned off when I brought the lamp to that position. Do you know whether you are doing sas from the ground or your brain and you know the master in Kutahya
08.05.2020 14:05 # 16
SonerHoca
Ağlama I have 2000 models 406 diesels. When traveling on the straight road, km was stopped and the dials started flashing and not moving. Clicking, clicking, clicking, clicking, clicking, flashing. I stopped the car immediately. continued . I removed the contact and continued. I removed the battery, stopped :) anyway, I thought the vehicle had a brain socket or something. I took it off and put it back in. Then I hooked up the battery and stopped doing it. Until Taaaki opened the door. He continued as soon as he opened the door. I said Nesye and came to the village at the top of the mountain. There is no problem working on the engine but no dial is working. I came back to my house before I could remove the battery and lock the doors. I am in a village at the beginning of the mountain. PLEASE GIVE ME SMART.
08.05.2020 14:05 # 17
BurcUMUL
The problem is great, but there is no answer.
08.05.2020 14:05 # 18
H-a-d-i
Friends, I know that this member has been removed from the site or left the discussion because he was not sincere when he wrote. your questions remain unanswered.
08.05.2020 14:05 # 19
FTH
If you have so many questions, normal :) reply to someone :) :)
08.05.2020 14:05 # 20
er_88
Master, I have 406 1998 model sv bva automatic gearbox, 4hp20 gearbox, the gear shifts like wasted and does not eat gas like a half clutch. er_88 2017-08-14 19:30:13
Page : / 2
